Door Switch question
Old Jun 29, 2004 | 09:07 AM
JeremyFXDWG's Avatar
JeremyFXDWG
I am trying to put kodiak sidewinders on my truck. I have them all mounted up and wired except for the "actuator" wire. I wanted to try to use the door switch built into the truck to trip a relay to ground out the "actuator" on the step. (BTW.. thats how the steps work. You put the actuator wire to ground to make the step come down). I do not want to use the ugly door switch they give you with the kit. Does anyone know of a wire that has voltage when the door is open? Also i want it side specific so the dome lite circut will not work.
Jeremy
Old Jun 30, 2004 | 10:35 PM
Dealford's Avatar
Dealford
Welcome to FTE!
What year is your truck?
Pull the factory door switches for the courtesy lights. If they are wired with both + & - leads, get the instructions out for the steps & splice into the ground lead of one switch. Then open the OTHER door. If I understand how the steps run, this should work.
AL.
CUINAK
Sep 27, 2019 10:48 AM
smh111
1978 - 1996 Big Bronco
Apr 1, 2015 04:20 PM
ryankerr
Electrical Systems/Wiring
Mar 5, 2014 10:06 AM
Langpie
Nov 14, 2012 09:04 PM
FUJINAMI1293
Jun 17, 2012 08:03 AM
