Back door
Old Jul 31, 2002 | 08:47 AM
k wilson's Avatar
k wilson
Back door
My back door broke. The hydraulic lifter fell off. and the plate that the lifter is welded to fell off too. "Anybody else having this problem".. Anybody have any experience fixing this??? Guess I'll have to get my dad to weld everything back up. The door doesn't shut right either.
By the way its a 97 XLT thanks
Old Jul 31, 2002 | 09:35 AM
adbradley's Avatar
adbradley
Back door
Pre-95 models had a recall on this. It was for a replacement hings bracket because the old ones would break off. You might try your Ford dealer and see if yours is recalled or maybe they can get you a better replacement. I would think that a weld on body sheet metal might not be enough to support the weight of the liftgate...
Old Aug 1, 2002 | 08:19 AM
k wilson's Avatar
k wilson
Back door
Called Ford dealer no such recalls on mine. ......
I think I will def have to by a new hydraulic and weld the plate
back up and hopefully it will hold. As it is now, the door doesn't
even shut right.
Old Aug 3, 2002 | 12:20 PM
Dialtone's Avatar
Dialtone
Back door
Check the latch bolts for broken/missing strike bushings. There should be a plastic bushing over the bolt shaft that protrudes from the inside edge of the door frame. If it is missing, it will cause the door latch to not grab hold properly. You can purchase a bushing kit or the entire bolt/bushing assembly from most auto supply stores. Bushings kit is <$5, bolt& bushing is $5-7 each. Replace the entire bolt if it shows signs of wear on the shaft (safety first).
Dialtone
Old Oct 23, 2002 | 06:12 PM
dragonblade's Avatar
dragonblade
Back door
I got hit in the liftgate on my 1992 ford Explorer sport. The hit was just below the handle, not to bad to look at but now I can't open the gate or the window so I cant fix the dent!
any ideas on how to get the gate open?
Old Oct 23, 2002 | 07:42 PM
ckrichard's Avatar
ckrichard
Back door
>dent!
Please start your own post. Don't tack your questions on to another persons.
Chris
Old Oct 23, 2002 | 09:01 PM
Opera House Works's Avatar
Opera House Works
Back door
J2H
17
Jul 7, 2024 07:48 PM
foofees
Escape & Escape Hybrid
Sep 15, 2014 12:57 AM
wmiller
Apr 29, 2014 03:07 AM
Fifty4F100
Aug 31, 2009 04:35 PM
MikeRizz
May 22, 2006 03:44 PM
