Bleeding Brakes????
Old Jun 24, 2004 | 10:18 PM
spencer5148's Avatar
spencer5148
Question Bleeding Brakes????
I just install new brake calipers and brakes, On my 1962 Ford F100. After bleeding, They fell just fine until I start the engine then I lose all compression. I have also tried bleeding the with the engine running and nothing. So can anyone please help here, It would be very much appreciated. Oh I do have the disc conversion in the front.
Old Jun 25, 2004 | 06:29 AM
ddavidv's Avatar
ddavidv
Power brakes?
My first thought is you have a bad booster that is sucking the fluid out of the master cylinder when you start the engine.
Old Jun 25, 2004 | 01:45 PM
William's Avatar
William
Well for sure its a booster/vacuum related. May be the pedal linkage? The booster diaphram is moving in response to engine vacuum, so you may have check valve issues, booster size issues or linkage issues. More info please. Arent you using Dodge rotors and the rest Ford? Post back we love these puzzles! And, "Welcome to FTE"!
Old Jun 25, 2004 | 02:38 PM
spencer5148
Not On this truck am I using the dodge brakes, This truck is the original Disc swap, $400.
Old Jun 25, 2004 | 04:34 PM
spencer5148
So can someone please tell me how to test the booster or the Vac? Thanks
DLGries
1983 - 2012 Ranger & B-Series
Mar 22, 2024 08:02 PM
colokerrie
Dec 26, 2012 11:08 PM
davebrown
Large Truck
May 20, 2011 01:20 AM
jleo
Apr 4, 2010 01:29 PM
toolman617
Jul 11, 2005 12:12 PM
