Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1986 F750
Old May 18, 2011 | 10:34 AM
davebrown's Avatar
davebrown
1986 F750
Need some help in bleeding the brakes on my 1986 F750 dump truck.
I have taken care of the brake master cylinder bleed - no problem.
How do I bleed the system that has the ATF fluid in it? I located 2
bleeder valves but have no idea how to bleed the system. Any help
would be much appreciated by this Montana cowboy who is stuck.
Old May 18, 2011 | 01:07 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Try down here boss Large Truck - Ford Truck Enthusiasts Forums They might be better suited to help ya as this is the 2009-up F150 section of the forum
EDIT: Yes, welcome aboard!
Old May 18, 2011 | 01:11 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the Large truck forum - WELCOME to FTE!
Old May 20, 2011 | 01:20 AM
rummur s.c.'s Avatar
rummur s.c.
Just crack the bleaders on the e brake cans until fluid comes out of each. Have to push the **** on the dash in to get the fluid to flow. And the engine needs to be on.. Probably should chock the tires so no body get run over.
srumble
Nov 17, 2007 06:36 PM
JJayP
Jun 25, 2006 08:53 PM
fatboy95
May 25, 2005 03:05 PM
Willie gomes
Dec 17, 2003 04:20 PM
1984_355w
21
Nov 2, 2002 04:39 PM
