Square peg, round hole
Old Jun 24, 2004 | 08:12 PM
Michael McKendrick's Avatar
Michael McKendrick
I have a 1980 F250 4x4 with a blown I6 (I posted about it earlier this week). I found another engine, in a 1976 F100. I was cautioned to make sure it's a 300 and not a 240...question I have is...how do I tell? Apparently the engine is the same on the outside with only a crankshaft difference. The seller didn't know when I asked him about it. I have a real potential at this point for a creek ride sans paddle.
Old Jun 24, 2004 | 10:53 PM
MontanaFord's Avatar
MontanaFord
according to the chilton i have, the only inline six available in 76 was the 300...so you should be safe...if you can...look at the VIN on the 76...if the 8th digit is a "B", you have a 300-6...if it is an H, Y, or A, the six is not the stock motor...but i'm thinking that it would be, due to the fact that it's a 1/2 ton truck...good luck...
MontanaFord
Old Jun 24, 2004 | 11:55 PM
63redtudor's Avatar
63redtudor
The last of the 240s were used in trucks in '74. Unless the motor was swapped out at one piont in time then you're most likely just fine.
Edwin
Old Jun 26, 2004 | 12:59 AM
Michael McKendrick
Yeah, but...
...I don't know if the thing has the original engine in it, so it may conceivably be a 240...is there a way to positively ID it visually? The VIN code is B, it's from a 76, but who knows? I know who HAS to know, and it's me, and before I try to install it with my three rusty spanners and my Wal-Mart 101 piece socket set.
Old Jun 26, 2004 | 09:15 AM
bremen242's Avatar
bremen242
the motors are physically the same.. there should be some numbers on it... I've never even seen a 240, but if you goto www.fordsix.com, they'll have a lot more info on older sixes.
perhaps these casting #s will help:
http://www.fordsix.com/inlinesixdata.htm
shockr4
2004 - 2008 F150
Feb 15, 2014 08:37 PM
leerider524
Feb 11, 2010 06:22 PM
leerider524
1997 - 2003 F150
Feb 11, 2010 04:32 PM
6T8STANG
1997 - 2003 F150
Jun 18, 2003 03:13 PM
4x4akvan
Sep 12, 2002 09:21 PM
