amp guage
Old Jun 23, 2004 | 07:37 AM
edselranger59's Avatar
edselranger59
amp guage
HI can someone tell me where i would hook up amp guage wire's
Thanks
Old Jun 23, 2004 | 07:40 AM
Putt's Avatar
Putt
We need to know what type of amp gauge it is. Is it oe or aftermarket?
Old Jun 23, 2004 | 08:15 AM
edselranger59
hi it is a aftermarket one
Old Jun 23, 2004 | 08:29 AM
Putt's Avatar
Putt
AM amp gauges hook in between the alt./gen. output and the battery side of the starter solenoid. You need to use HEAVY gauge wire and make sure the ammeter has a higher rating than your alt/gen. I used 10 gauge wire for my instal with a 65 amp alt. and have had no problems. Keep your wires as short as possible and use good connectors at each end. DO NOT splice the wires. It would also be a good idea to add a fusible link in the circuit to protect the wiring.
Old Jun 23, 2004 | 08:43 AM
edselranger59
on the solenoid do i put it where the battery cable bolts on or on one of the top terminals?
Thanks
Dave
Old Jun 23, 2004 | 08:52 AM
Putt's Avatar
Putt
You hook to the same large post your positive battery cable runs too. You must remove the wire from the solenoid that now comes from the alt/gen. That wire must hook to new wire you install that runs to amp gauge. Then run new wire from other side of amp gauge to solenoid where oe wire was.
Old Jun 23, 2004 | 01:26 PM
76supercab2's Avatar
76supercab2
I recommend against amp meters for cars in general. They are potentially dangerous and don't really give reliable information.
Dangerous because to be accurate, all the current going into or out of the battery must pass through it. Since the meter is in the cab, a heavy guage wire must be run up into the dash and back out to the battery. If this wire gets frayed it will cause a short that could start a fire.
Unreliable: If you connect it where suggested (which btw is where the factory puts it) you only get an idea if current is going into the battery during the charge cycle. After the battery is charged the current will drop to near zero. In order to get an accurate picture of the charge or discharge state of the electrical system the alternator and general electrical hookup to the rest of the truck should go to an insulated post that is not the starter solenoid. Then a wire should go from this post, throught the ammeter and back to the battery side of the solenoid. This will then tell you if current is flowing into the battery (charging) or out of the battery (discharging). The current to the starter would not go through the ammeter so it will be protected from that high surge.
A much simpler, safer and more accurate guage would be a volt meter. Connect between a 12V source and the chassis of the vehicle.
BTW, this is the wrong forum for this question
Old Jun 24, 2004 | 07:59 AM
Ratsmoker's Avatar
Ratsmoker
What year truck is this?
Old Jun 24, 2004 | 08:34 AM
edselranger59
well actualy its a car i just poasted on this forum becuse it has a 332 FE engine.
The car is a 1959 edsel Ranger 2 dr ht
Old Jun 24, 2004 | 02:15 PM
Ratsmoker's Avatar
Ratsmoker
You are fine, I was just wondering.
