Strong Gas Smell
Old Nov 22, 2002 | 11:21 AM
xtra1es's Avatar
xtra1es
Strong Gas Smell
HELP!....I'm getting a stong gas odor. It seems to be coming from the area of my rear drivers door. There is not anything leaking. I replaced the gas cap(thinking it was letting fumes out)..didn't help.
It's a 1993 4Dr E.B. 4x2.
Old Nov 22, 2002 | 11:35 AM
xtra1es's Avatar
xtra1es
Strong Gas Smell
oh ya....doesn't seem to be running any different or going through any more gas. It happened right after my last fill up.
Old Nov 22, 2002 | 11:40 AM
Opera House Works's Avatar
Opera House Works
Strong Gas Smell
The charcoal canister is under the hood and there is a tube that brings the vapors there. There may be a bad connection to that, The ring seal on the tank that holds the fuel pump or the fill connections. Most gas leaks are easy to find, the gas washes them clean. You'll just have to get under here and inspect them all.
Old Nov 22, 2002 | 12:47 PM
xtra1es's Avatar
xtra1es
Strong Gas Smell
there is def not a gas drip.....must be the vapor line to the canister...i'll take a look and let you know...thanks!
Old Nov 22, 2002 | 06:30 PM
hrbib21's Avatar
hrbib21
Strong Gas Smell
scottperkins
1997 - 2003 F150
Jun 29, 2016 10:33 PM
Slapinator
Jun 25, 2015 03:40 PM
ssparkman
Modular V8 (4.6L, 5.4L)
Apr 2, 2013 11:37 AM
olblue76
Dec 28, 2011 06:25 PM
breedo99
13
Mar 25, 2010 09:07 PM
