baffled
Old Jun 22, 2015 | 12:02 PM
Slapinator's Avatar
Slapinator
baffled
1991 F-350 460 efi I have #4 plug out and it's dumping gas. Ive cleaned all 8 injectors, I switched #2 and #4 around. #2 is not dumping gas. #4 still dumping. Disconnected #4 electric and #4 is still dumping fuel. Can't get truck to start. With #4 spark plug in, it hydro locks from all the gas flowing. Pull #4 plug and the motor will turn, but spewing gas every stroke. Any help???
Old Jun 23, 2015 | 11:08 PM
6ohdslbilder's Avatar
6ohdslbilder
You my have a plugged fuel rail. Your fuel feed crossover is at the number 4 injector. Pull your fuel rail and disable the coil. Remove number 1 injector and turn your key on. See if fuel dumps out at number one location. Then install it and pull number for and compare fuel flow a month between the 2.
Old Jun 25, 2015 | 03:40 PM
Turbo Dog's Avatar
Turbo Dog
Or it's due to the signal from the ecm. I would need an oscilloscope or at least a meter capable of measuring the duty cycle to find out if the ecm is incorrectly holding that injector open.
PalaniRides
1997 - 2003 F150
Jul 1, 2018 02:59 AM
Bronco1988
Bronco II
Sep 2, 2016 10:32 PM
tuekwik
Nov 20, 2005 11:34 PM
kikishod
Jul 25, 2004 06:31 PM
