95 Explorer OBDII Expert Help Needed!!!
Old Nov 8, 2002 | 06:05 PM
marragtop's Avatar
marragtop
I have a '95 Explorer and I need to get the codes out of it. It has a 16 port connection under the dash which I assume is the code reader port. It doesn't have the 3/4 prong connector(EECIV) under the hood that the earlier explorers have. I borrowed an OBDII scanner, but the code comes up '8888', which according to the scanner manual means I'm not getting any signals. I've heard that the '95 was a transition year for Ford and that the connection I have on the truck may not be OBDII compliant. This would mean that I need a different scanner that most likely will only work on this year vehicle. Also, the factory sticker under the hood says it meets emissions standards, but does not mention OBDII, OBDI, EECIV, or EECV. Some people I've talked to say that the sticker should tell me. That's not true in my case. I'd appreciate any and all advice. Thanks in advance..
Mike
Old Nov 9, 2002 | 06:47 AM
Opera House Works's Avatar
Opera House Works
Although I am not familiar with this engine, it is my understanding that in the 95 the "OBD-II" connector was only for the Ford non engine diagnostics and that this engine was still OBD-I
Old Nov 10, 2002 | 12:14 AM
pita's Avatar
pita
95 is a transition year it can have both connectors but if it only has the one then it should work on any OBD II scanner.The connector should have a hot wire in run you could check if not maybe the fuse is blown and thats why you scanne isn't working. I would also check real good under the hood if has a connector out there should either be beside fuse box or on pass side next to the heater box.
Old Nov 15, 2002 | 07:28 AM
Opera House Works
Old Nov 27, 2002 | 11:18 AM
lyonsexp's Avatar
lyonsexp
Post 95 Explorer OBDII Expert Help Needed!!!
I have a 95 explorer, the diagnostic link is on the front-side
of the power distribution box under the hood driver-side fender.
6-pin connector with one independent lead(this is not considered
an "OBD-II" system). You can use either a analog voltmeter or the
check engine light itself and jumper wire. This system has a built
in self-test system.
0500757Arf
31
Feb 11, 2018 08:18 PM
BWD444
Electrical Systems/Wiring
Dec 30, 2016 07:52 PM
BWD444
Dec 27, 2016 04:05 PM
KG Excursion
Modular V10 (6.8l)
13
May 9, 2014 01:13 PM
apropos
General Automotive Discussion
Sep 14, 2005 12:56 AM
