ignition question
Old Jun 20, 2004 | 03:07 PM
skelator's Avatar
skelator
ignition question
i want to install an msd-6a off road ignition system in my bronco, will this replace all of my current ignition components?
Old Jun 20, 2004 | 04:54 PM
Franklin2's Avatar
Franklin2
You will still have to use the pick-up system in your distributor, unless you buy a MSD replacement distributor too. If you go to their website, they have a long list of hook-up options for different set-ups. I have never had one, but I believe one of the advantages of the MSD dist is the adjustablility of your timing curve. You have to tear into the Ford dist to do this(change the weights and springs, etc).
Old Sep 17, 2004 | 02:54 PM
skelator's Avatar
skelator
thanks
i am planning on replacing the entire system with msd products. as far as i am concerned the only people that did a worse job in wiring their vehicles was jaguar back in the 70's.
BuckHunter1960
May 22, 2016 03:47 PM
shotgun64
Aug 26, 2015 05:14 AM
loganmick
16
Jul 11, 2015 05:09 PM
86f250xl
Large Truck
Apr 2, 2015 06:15 AM
frankb
New Member Introductions
Jul 8, 2006 05:37 AM
