2bbl or 4bbl?
Old Jun 17, 2004 | 11:48 PM
78broncoman's Avatar
78broncoman
2bbl or 4bbl?
Iam getting ready to put a 390 into a 74' F250 4by and was wondering which should I go with because I already have two 2bbl intakes and carbs but I can get a 4bbl intake for $40 and a 4bbl holley for $100 I have to money to buy them but I dont know which I should do. It will be my daily driver for awhile and it will see alot of back roads I need it to get fair gas milage and it has 4:10 gears and a 4spd. What do yall think?
thanks
Matt
Old Jun 18, 2004 | 12:12 AM
fordman428's Avatar
fordman428
id get the 4 barrell, some people sware a 4 barrell will get better gas milleage, but if not it will boost the power a bit.
Old Jun 18, 2004 | 12:29 AM
fordeverpower's Avatar
fordeverpower
get the 4bbl. it won't use more gas unless you want to!
Fordman428, I think the spread bore should have been good on gas mileage considering the primarys were small unlike the secondaries.
Old Jun 18, 2004 | 01:04 AM
samckernan's Avatar
samckernan
Get the 4 barrel and put the heavy spring in the secondaries. Most of the time it'll be just a two barrel, if you really slam it, like if you have to pass, the secondaries will kick in... giving you more power (using more fuel), other wise, it'll be just like a 2 barrel.
Just my 3 cents.
Sam
Old Jun 18, 2004 | 10:01 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I agree with the other guys...
One other thing, the primaries on a 4bbl carb, even a square-bore, are smaller than a stock 2bbl's venturies. This will get higher velocity through the carb into the intake, getting you MORE bottom end then the stock 2bbl (all other things being equal). It also helps the fuel/air mix. For a 4x4, it'll certainly help. And, like everyone said, better mileage.
I took a stock 360 w/2bbl with over 100K miles, put a Holley on it with an 4-to-2 adapter (yeah, I know, but it was free), and got BETTER bottom end and raised the peak torque up the RPM curve. I would imagine putting a 4bbl intake on would have only made it better.
Old Jun 18, 2004 | 01:05 PM
led sled's Avatar
led sled
i would go with the 4 barrel also, the primaries of the 4 barrel are smaller then the ones of a 2 barrel, results better gas milage. also you would already have the 4 barrel if you did any type of build up on the motor. good luck
Bwillden24
Dec 20, 2010 10:07 PM
icuhatn99
Feb 5, 2006 10:35 PM
blackgtstang
Aug 18, 2005 03:11 PM
calazo
Jun 4, 2004 03:12 PM
rticwrrior2000
1978 - 1996 Big Bronco
Jul 31, 2003 04:13 PM
