bed rail too high
Old Jun 14, 2004 | 09:09 PM
talanhmi's Avatar
talanhmi
bed rail too high
Was looking at the new Ford F 150 and even brought it home for the night but when I back it up under my 5th wheel there is only about 1 inch clearence from the bottom of the 5th wheel to the top of the bed rail. Any suggestions on what to do about this problem?? Thanks
Old Jun 14, 2004 | 10:55 PM
johnsdiesel's Avatar
johnsdiesel
Get a Super Duty. Sorry, that's the first thing that came to mind. I knew that when Ford redesigned the F150 they didn't do so with fifth wheels in mind since most are too heavy for the F150. You can always raise the height of the trailer or lower the truck.
Old Jun 14, 2004 | 11:15 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I agree, F150's are not enough truck for most 5th wheel trailers, and as you noticed, they also made the bedrails too high. I would want 6" or more clearance between the bedrails and the trailer, especially if you go down rough dirt roads with it.
Old Jun 15, 2004 | 10:03 AM
85BigBlock's Avatar
85BigBlock
Get the adapter to change from the plate style hitch to the ball style hitch. You should be able to squeeze at least 6" out of that and have a roomier(sp?) bed.
Old Jun 15, 2004 | 03:20 PM
johnsdiesel
85BigBlock, forgive my ignorance, but how is changing the hitch style going to give more bed rail clearance? Without raising or lowering the truck and/or trailer when the trailer sits level (which is a must) it will still have the same bed rail clearance regardless of hitch style.
Old Jun 15, 2004 | 03:28 PM
85BigBlock's Avatar
85BigBlock
well ya put it like that for some reason I was just thinking, make the trailer higher.
Old Jun 15, 2004 | 04:12 PM
Steina's Avatar
Steina
CO River Rat
johnsdiesel -
Forgive my ignorance, but how is lowering the truck going to increase bed rail clearance? Dumb me, I just assumed the hitch (being mounted in the bed) would be lowered along with the truck.
Steve
Old Jun 15, 2004 | 04:24 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Man, it sounds like the dealership's must be pushing the F150 as the new super SUV that can do anything...
Why are you giving the F150 even a second look if you need a truck that can pull a 5th wheel? Take it back and negotiate a deal on a Super Duty. Since you took the F150 home overnight, they are expecting a sale and will do a lot to keep you from walking away.
I wonder why they designed the '04 F150 with such high bed rails. It seems to me that Ford is abandoning one of their biggest customer's, women. It was women, IMHO, that helped the '97 F150 continue Ford's claim to be the "best selling truck..." Maybe they are trying to get away from the image of the F150 being a 'chick truck', but it seems to be us guys that keep pointing out that the bed is too high to reach into.
Old Jun 15, 2004 | 06:01 PM
johnsdiesel
Steina, my parents fifth wheel pin is adjustable. I don't know if most are or aren't. The main issue is getting the trailer to sit level. If the truck was lowered, which for an F150 probably isn't an option, when the trailer sits level it would do so a bit higher above the bed rails.
Old Jun 15, 2004 | 08:41 PM
04superduty's Avatar
04superduty
cant you put a lift on the trailer axles?? my uncle had his rv dealership do it to his 5 th wheel to make it sit level. with some trailers you can put the axles over the springs, others the process will be more involved.
mav
6.7L Power Stroke Diesel
Jul 10, 2013 10:34 PM
Tylus
All Things Towing
17
Jun 4, 2012 01:48 PM
kabur66
May 12, 2011 07:07 AM
Champ198
Aug 22, 2010 09:04 PM
