Sponsored by: Auxito
blend door
Old Jul 1, 2023 | 01:34 PM
Donso's Avatar
Donso
6th Gear
Originally Posted by Donso
97 f150..base 2 dr.4.2 automatic...Ok...air blows cold then sounds as if door in dash closes or moves then blows hot. Turn it off wait a few seconds and air blows cold. For no apparent reason it changes. Seems to do this often in stop and go traffic. Worse time of course. Thanks for comments.
blend door was broken. Not sure if other components are ok.
Old Jul 2, 2023 | 06:57 AM
manicmechanic007's Avatar
manicmechanic007
You haven't lived until you pull the HVAC case and replace a blend door the right way
Pretty big job
Steering column out, dash on the seat for starters
That blend door job should take about 9 hours to do it right
Old Jul 6, 2023 | 04:22 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Pretty big job
Yep and if doing it pop in a fresh heater core. I did on my '01 Screw.
Label and bag ALL the stuff.
Old Jul 6, 2023 | 08:50 PM
manicmechanic007
Absolutely, and replace both or all three of the actuators
You only want to do that job once if you can help it
Alex Furrh
Jan 1, 2021 07:44 PM
ScottInTexas
1997 - 2003 F150
Dec 25, 2008 06:46 PM
jdew1920
Sep 25, 2006 07:45 AM
Truck Time
Jan 21, 2006 08:37 PM
imsorope
1983 - 2012 Ranger & B-Series
Oct 11, 2003 10:23 PM
