Adding a third battery
Old Jun 14, 2004 | 03:22 AM
browning1919's Avatar
browning1919
I have a few extra truck bats and was wondering about the possibility of putting a third in the truck. I need to replace to worn cables anyway, and thought it would be nice to add a little extra cranking power in the process. Would the increased amperage have any negative effects, and do all the bats. have the have the same amp rating?
Thanks for any help,
Mike
Old Jun 14, 2004 | 04:10 AM
fellro86's Avatar
fellro86
I would think it should be ok, as the amp draw will dictate the flow, not the reserve power.
Old Jun 14, 2004 | 05:18 AM
trike1946's Avatar
trike1946
Yeah, it should work. Where are you going to put it? Why not just two more powerful batteries?
Old Jun 14, 2004 | 05:07 PM
rhicks_all_taken's Avatar
rhicks_all_taken
I added a third battery about 5 months ago. I use it to run a 110v inverter for accessorys like my computer and TV. The 3rd battery is isolated so my inverter wont discharge all my batteries and leave me stranded. however it does kick in to help start the motor when the key is turned on. The only thing I have noticed about the setup is that the volt meter is showing 10.5 volts instead of 12v am guessing this is just because the system is having to charge 3 batterys instead of 2.
Old Jun 14, 2004 | 07:49 PM
browning1919
I was planning on putting it over the passengerside wheel well. I would just need to move the vaccum sensor and maybe the voltage regulator, otherwise, there is plenty of clearance for it in that area. I'd rather use the batteries that I have than buy two higher output ones.
fragmentalstew
46
Oct 16, 2014 12:13 AM
gasguz
Aug 21, 2012 08:49 AM
924x2150
23
Aug 20, 2007 06:47 AM
firefighterF250
Dec 8, 2005 06:41 AM
racerp419
Nov 12, 2005 11:39 PM
