Ft 361
Old Jun 13, 2004 | 09:44 PM
Ratsmoker's Avatar
Ratsmoker
It is a little over 7:1. I don't know of any 360 piston out there that will give you 9.5:1. Best thing to do if you bring it down that far is to get a 391 crank and rods from somewhere and swap it in. Then get some KB hyper pistons which will give you about 9.5:1 if you polish the combustion chambers out a little.
Old Jun 14, 2004 | 10:57 AM
rusty70f100's Avatar
rusty70f100
I think he should look at the crane 343971. Even milder than the 901, and would probably work better with the FT.
Old Jun 14, 2004 | 08:24 PM
DT 466Man's Avatar
DT 466Man
thanks for the advise i am going to buy this truck to drive to school and tow hay so i want it to look and sound good
it is a 1972 F600 flatbed with low sides and new wood the sides are removable. It is a 4sd 2sp and juice brakes. Where can i get acc. brackets to hold an air compressor from an air brake truck a want to have onboard air to run tools and change tires.
Old Jun 14, 2004 | 08:45 PM
Ratsmoker's Avatar
Ratsmoker
Hit the junkyards man. There are several out there. You just have to find them!
Old Jun 15, 2004 | 06:37 PM
DT 466Man's Avatar
DT 466Man
thanks did F600's come with air brakes?
or was it just the 800's
mudslinging79
Bronco II
Nov 2, 2007 07:33 PM
87b2guy
Bronco II
Feb 21, 2005 12:59 AM
Redneck-Cowboy
4 Cylinder Engines
56
Nov 5, 2004 12:55 PM
big88b2
Bronco II
Nov 30, 2003 09:22 AM
stumpy2
Apr 14, 2001 10:19 PM
