Heater core shutoff valve?
Old Jun 12, 2004 | 01:54 AM
Kynetx's Avatar
Kynetx
Is it possible to put a valve in the heater core supply hose to cut off flow in the summer? It seems that it's impossible to keep it from pumping out heat even when the heat control is all the way off. I'm concerned about possible damage to the heater core and hoses. Will stagnant coolant harm anything?
Old Jun 12, 2004 | 03:44 AM
19gator55's Avatar
19gator55
There should be a Heater Control Valve installed in the upper radiator hose. If you look at the pics in my gallery you'll see what I mean.
Old Jun 12, 2004 | 07:09 AM
mrmoo's Avatar
mrmoo
Check around your heater box for a loose vacuum line, I had one on mine and I didn't know what it was until one day I tried to see if it had vacuum and to my suprise the temp selector controlled it. So I took the valve off my old chevy and put it on there and now it works great! You need a valve that's normally open.
Really easy to install, just raise whichever hose as high as you can and slice it open, I had no leakage, then just slip in the valve and tighten the clamps, and you're done!
Old Jun 12, 2004 | 10:12 AM
Kynetx's Avatar
Kynetx
Cool! That's what I thought. Thanks for the info.
Old Jun 12, 2004 | 10:53 AM
Ecuri's Avatar
Ecuri
NAPA has the replacement for about 17.00 and it is N/C.
conoso
Jun 18, 2016 07:32 AM
1974xlt
15
Mar 26, 2016 06:49 AM
jstephens2
22
Sep 13, 2011 08:21 PM
cebru
Oct 3, 2004 05:07 PM
elstx
Jan 16, 2004 06:20 AM
