Heater control valve?
Old Jan 14, 2004 | 11:01 PM
elstx's Avatar
elstx
What is supposed to move the heater control valve that connects the hose(s) to the heater core? Should something be connected from the controller in the truck through the firewall to the heater control valve?
Old Jan 14, 2004 | 11:11 PM
Mil1ion's Avatar
Mil1ion
A cable on the heater control panel.
Old Jan 14, 2004 | 11:13 PM
elstx's Avatar
elstx
Thanks. Now I will have to look for one of those when I get a new heater core, which is leaking. Will probably have to get the control valve also.
Old Jan 14, 2004 | 11:37 PM
Mil1ion's Avatar
Mil1ion
It should operate a door on the heater box.
The only thing heater core's get is 2 hoses attached to it.
Sometime's I forget which forum i'm on.
Do you have a cable that runs to a valve on one of the heater hoses under the hood ?
It seems to me truck of that era had them.
I don't have a photo.
Old Jan 14, 2004 | 11:39 PM
elstx's Avatar
elstx
I have a controller valve between 2 heater hoses in the engine compartment, it looks like some type of cable should connect to it which I assume is to one of the heater controls in the cab.
Old Jan 15, 2004 | 12:08 AM
gtex's Avatar
gtex
Your assumptoin is correct. There should be a cable running to the heater temp control slide switch in the truck.
Old Jan 15, 2004 | 08:32 AM
Freightrain's Avatar
Freightrain
I see from one of my resto catalogs that the cables are available: temperature control $10 (68-72). The '67 model uses a different set of controls than the newer trucks.
No doubt someone broke it and it just needs replacing.
Larry
Old Jan 15, 2004 | 09:34 AM
gtex's Avatar
gtex
It may have broke or been removed when the valve got stuck. The old metal valves will freeze up when not used for a while. Check the valve for movement. If it's froze up, replace it as well.
There are reasonable replacement valves made of plastic at your local parts store. Don't know about the other guys, but I don't have an issue with plastic parts in the cooling system....plastic don't rust :-)
Old Jan 15, 2004 | 11:55 AM
Freightrain
Yup, the metal one will get stiff, and then if you try to FORCE it with the cable, IT WILL KINK!! Then it's all junk.
The one in my '67 was metal and worked great. Did not much use it all summer....then when I tried this fall, it was STUCK . I then replaced it with a plastic one.
With my luck...it will crack.
Larry
Old Jan 15, 2004 | 07:41 PM
elstx's Avatar
elstx
Thanks for all the help.
Old Jan 16, 2004 | 04:16 AM
mamafedmepaintchips's Avatar
mamafedmepaintchips
I glass beaded my valve when it seized up and it worked perfectly. I did it about 3 years ago and all it has now is a little surface rust. Now and then a little shot of wd40 keeps it turning smoothly.
Old Jan 16, 2004 | 06:20 AM
jds1971's Avatar
jds1971
My slider in the dash sticks no matter what type of lube I use so I ran an aftermarket choke cable to the heater control valve under the hood.
Joe
diesel 04 X
Dec 1, 2024 10:24 PM
Jolly Roger Joe
31
Mar 9, 2017 09:29 AM
AZHIBoy
Oct 15, 2016 05:28 PM
conoso
Jun 18, 2016 07:32 AM
99hosss
Nov 23, 2011 03:51 PM
