Latest FLASH?
Old Jun 10, 2004 | 07:05 PM
  #31
FastF350's Avatar
FastF350
no, in my other thread i found out enough info that suggest that unless you run alc/water injection and also change injectors it is not very smart. With my 13.7 1/4mile i am extreamly happy with my edge(attitude) i really just need the speed delimiter and the shift point control.
I believe i read that the predator was able to change rev limit, adjust shift and speed but i have not been able to figure it out yet.
Old Jun 10, 2004 | 07:36 PM
  #32
jdadamsjr's Avatar
jdadamsjr
NO,
predator will not do rev limiter, or allow adjutabel shifts... but it will remove spped limiter...
It will change the shift line pressure to allow quicker shifts, but the rev limit is not necessary...
it goess thru the gears so FAST, you wont need the rev limiter changed....
Try your 1/4 with just the predator - you'll be surprised... shifts better than if you were power shifting a std...
it is AT least +100 RWHP and mine measured 710 ftlb ...
Old Jun 10, 2004 | 07:56 PM
  #33
FastF350's Avatar
FastF350
I wonder and you might know can i ask them to make a custom tune just for the speed limiter and shift line pressure? If not then there is no reason for me to keep it. The performance is better with the edge although the predator is/or seems much smoother... could be the shifting
Old Jun 10, 2004 | 09:35 PM
  #34
SBV45's Avatar
SBV45
Originally Posted by jasfaa
There is no sticker, this is what the paper work says.
6359 performance diag sheet wds test no dtcs fuel good, oil good, visual insp good, reprogramed ficm to latest calibration post test normal o
EN06 engine repairs misc
3979 WF
I am sure this all is their billing codes. It definitely idles differently and does not have much of a knock at idle.
None of that looks like the code rev. If your engine build date it 10/03, I am pretty sure you have an 04 engine. 04 engines are later than 9/30/03. If that's the case there is only one flash for it. Update Code RC1, WDS Level B29.6
Symptoms addressed:
Improved cold hard acceleration at High Altitude
Runs Rough after Extended Idle Cold Starts at High Altitude
Rough idle immediately following Cold Start
P2263 DTC MIL turned OFF on non California applications
Torqshift Harsh 3-2 coasting downshifts or clunk on tip-in/tip-out only in tow haul mode
P0299 Changes
P0500 Changes on Manual Transmission
Torqshift Harsh reverse engagements on Low Mileage trucks
You should be ok.
Old Jun 10, 2004 | 10:14 PM
  #35
jasfaa's Avatar
jasfaa
Good, I was actually a little worried because it feels different this time.
Old Jun 11, 2004 | 11:55 AM
  #36
BDU33's Avatar
BDU33
The right flash?
I must say that I haven't been here for a while. I must ask for some opinions. Currently I have 21K miles on the truck. At 7K I was experiencing rough start, jumping, and idle flux. I returned from Monterey averaging just over 18mpg (hand calc). I didn't like the idea of my rig "jumping" at the red lights, really rough starts, and rough idle. Well I went to the dealer and had it flashed at 10K. I know, I know...bare with me.
Since then my mileage has gone down to a measly 14.1..3 or so MPG freeway. No towing or heavy loads, just Cruising at 70 mph..like before.
Anyways I was checking out this thread and want o get your opinions as to whats the "latest" update. Is that B29.6 v just for the 04 motor?
I called the dealer and I had TSB 03-20-12 done on Jan 7, 2004. I have a sticker under the hood to reflect that. That TSB is v B27.9.
It's a June 03 motor. 6L w/torqueshift trans. The advisor on the phone looked up my vin and couldn't tell me if this "update" was available. The dealer is going to call me back after they talk to the deisel tech.
A little confused...can anyone shed some light?
Thanks,
Ford took some mileage from me and I want it back. Even if it's 1 or 2...but would like back all 4.
Puyallup Wa..
Old Jun 11, 2004 | 12:32 PM
  #37
buzzin's Avatar
buzzin
Thumbs up I've been happy since reflashing in Nov '04.
Currently running on the RC5 (17048) build. Sticker on radiator after update performed.
Might be a little louder but I don't care, it is a diesel for crying out loud.
No change to gas mileage.
Idle was improved.
Have not gotten the latest December update, since it doesn't appear to offer a whole lot.
FLASH contains the executable code the microcontroller runs along with various data tables. It is non volatile memory, meaning it is not erased when power is removed.
When the dealer reflashes, I am 90% sure they just reflash the entire memory. Then the dealer performs diagnostics to repopulate the calibration tables.
I imagine the performance enhancing gadgets out there just mess with the various tables.
I've often wondered if problems folks have after reflash aren't related to poor execution of recalibration procedures.
Old Jun 11, 2004 | 12:38 PM
  #38
BDU33's Avatar
BDU33
^^^^you mean Oct flash...right?
What was your mileage before the flash?
Do you have an 03 or 04 motor?
Thanks
Old Jun 11, 2004 | 12:53 PM
  #39
buzzin's Avatar
buzzin
Yup, the October Flash (update completed in Nov)
Currently have ~12,000 miles. Probably had around 4,000 miles when update completed.
Averaging between 18-20 MPG.
2003 F250 6.0L PSD, 5SD, SuperCab, XLT, 3.73 limited slip. 16" Alum wheels, Build date: 6/30/2003.
Last edited by buzzin; Jun 11, 2004 at 12:55 PM. Reason: left of engine build date
Old Jun 11, 2004 | 12:55 PM
  #40
FTE Ken's Avatar
FTE Ken
Please use the FTE galleries instead of posting links to other truck galleries.
Old Jun 11, 2004 | 01:28 PM
  #41
BDU33's Avatar
BDU33
^^^Sorry, gallery updated..
Old Jun 11, 2004 | 01:38 PM
  #42
BDU33's Avatar
BDU33
A little confused here...Your averaging 18-20 now with the Dec flash? What version does yours have? Like I said, mine is vB27.9, done Jan 04..TSB 03-20-12
We have the same motor build, same trans, same gears. Same drivetrain, different body configuration. I'm running 35's with mine and was then still getting 18mpg...not anymore. ????? Any ideas? Thanks
Old Jun 11, 2004 | 01:54 PM
  #43
buzzin's Avatar
buzzin
BDU33,
Sorry for the confusion. Should have put info in the message title, easy to over look.
Currenlty running the October FLASH not the Dec FLASH.
My only input is from the previous message, "I've often wondered if problems folks have after reflash aren't related to poor execution of recalibration procedures."
Maybe have your dealer run a diag and then rerun calibration procedures.
There is one other possibility. There are always tolerance issues with mass producing anything. This should be handled via the calibration tables in the FLASH. It is possible something in your motor is further out of tolerance then spec allows, so that the general algoriths don't work right. Or the programmers/engineers didn't proper compensate for valid tolerances in their code. Lots of variables to take in account, from manufacturing tolerances to climate ranges.
My daily drive consists of about 20 miles to work. 1/2 highway 1/2 back roads. I run 70-85 mph on the highway. It can't be that I'm lighter then you, I'm about 260 pounds.
NOTE: There were the same complaints of reduced mileage when the October FLASH was released.
Old Jun 11, 2004 | 02:08 PM
  #44
BDU33's Avatar
BDU33
BDU33,
What version do you have? I'm pretty sure I have the Dec flash....v27.9/TSB 03-20-12 since I took it in in Jan 04. I'll go down and talk to the deisel tech and pick his brain about this...what do ya think?
Thanks Buzzin
Old Jun 11, 2004 | 02:28 PM
  #45
SBV45's Avatar
SBV45
Go see: http://www.flatratetech.com/6literpo...l_updates.html for a good layout of the flashes for engines, part #s, etc.
