95 PSD engine problem
Old Jan 30, 2000 | 03:25 PM
sadsack's Avatar
sadsack
Can someone offer a suggestion? I have a 95 Ford
F-350 super cab fwd with about 90K miles.
Ryns beautifully with plenty of power (part of theTime).
Trouble started with ocasional momentary cut-outs.
Then it began to shut down for a second or more
then picking up to run ok.Now it will run fine
for a mile or two,maybe more then suddenly stop.
After repeated cranking it may start and run at idle. Attempting speed up and it quits. I have driven a mile or more at idle and gradually can
pick up speed and run fine for a while.
Any suggestions? One mechanioc suspected the
camshaft position sensor. but would it idle if
that were the problem> Thanks for any help.
Old Feb 2, 2000 | 11:06 PM
whd507's Avatar
whd507
it is almost definately the cam positioning sensor. you have all the symtoms and yes it will idle with a bad one.
Old Apr 2, 2000 | 05:08 PM
sadsack's Avatar
sadsack
>it will idle with a
>bad one.
I want to express thanks for the good advice.
I bought a new CPS and that solved the problem.
Cost about $150. Sadsack ##### Lewis
Old Apr 5, 2000 | 11:53 PM
nick's Avatar
nick
get your money back. the cps is covered under the emisions wrnty.i had mine done 5 months ago,all the same symtoms
Old Apr 30, 2000 | 09:00 PM
traxdude's Avatar
traxdude
get your money back quick...i had mine done at 96000 and also the wastegate and it was all warrenty
Old May 11, 2000 | 09:20 AM
deleontow's Avatar
deleontow
Old Jun 5, 2007 | 12:00 AM
krija's Avatar
krija
emmisions warranty on a '95? am i missing something?
Old Jun 5, 2007 | 03:22 AM
RubberDuck's Avatar
RubberDuck
That's what I'm thinkin' I don't want to throw salt on a wound, but you got hosed on the CPS. Powerstroke shop dot com has them for $15. Just FYI for the future.
But this warranty thing.........I would like to see some info on that.
Old Jun 5, 2007 | 07:01 AM
tjbeggs's Avatar
tjbeggs
Edit that response! Check out the date on this thread! this is a very old thread!
Old Jun 5, 2007 | 07:09 AM
RubberDuck's Avatar
RubberDuck
Wow! What the hell happened there???? Yeah, scratch that thread.
