Oops, I forgot
Old Jun 8, 2004 | 01:22 PM
rbdutton's Avatar
rbdutton
Oops, I forgot
Forgot to ask this question when asking about the brakes. Is it possible to remove the transmission cover and access the shift forks on a ZF 5 speed without pulling the tranny? I think I have a shift fork loose and would like to fix it without too much work.
Old Jun 8, 2004 | 02:00 PM
kitsapcountychopper's Avatar
kitsapcountychopper
if your truck has the removable floor panel <hump>then you should be able to access the top of the tranny .
Old Jun 9, 2004 | 12:51 PM
rbdutton's Avatar
rbdutton
Can the forks be removed from the top or do you have to remove the tranny first?
Old Jun 9, 2004 | 01:12 PM
kitsapcountychopper
the forks are located on the top of the tranny ,the shift housing unbolts and comes off with the shift forks attached.most likely it is the shifter bushing in the cup
frmach
1997 - 2003 F150
Nov 6, 2012 08:10 AM
keith66
Sep 8, 2011 10:36 PM
ozzy460
Dec 6, 2010 08:22 PM
norvillebob
Jun 16, 2010 04:32 PM
