toploader fork removal help
Old Jun 16, 2010 | 07:06 AM
norvillebob's Avatar
norvillebob
Hey all, I have a 4 speed toploader here that I need to remove the forks and shift rails. Can this be done from the top of the tranny without removing it from the engine? Any help would be appreciated.
thanks,
bob
Old Jun 16, 2010 | 11:18 AM
85e150's Avatar
85e150
Ford performance toploader 4 speed?
Exploded view here, looks like you might be able to if you can get to the top cover.
Exploded View of a Toploader
Old Jun 16, 2010 | 12:42 PM
norvillebob
yes and yes. actually it's a 4 speed OD unit from a 70's granada I want to make it into a top shifted box. I need to remove all the forks and rails.
bob
Old Jun 16, 2010 | 12:53 PM
85e150's Avatar
85e150
The OD unit is going to be slightly different inside as the shifting is reversed for 3-4 iirc.
There were top shift models of the OD, in addition to the turret shift and side shift.
Old Jun 16, 2010 | 12:58 PM
norvillebob
Jeep boxes t-176 and the ford TOD aluminum unit. And yes, I'm concerned about weather the shift pattern will be the same... the hotrod folks have been doing this on the three speeds behind flatheads using a jeep t150 shift tower. I found a few articles on the swap I'm attempting also, but nothing 100% on the OD unit.
bob
Old Jun 16, 2010 | 04:06 PM
EPNCSU2006's Avatar
EPNCSU2006
The TOD has an intermediate lever mounted on the left front of the case that reverses the direction of the 3-4 shift between the handle and the shift fork. I can try to borrow a camera and get you a few pictures if you think it would help.
Old Jun 16, 2010 | 04:32 PM
norvillebob
yes please.
bob
kha924
18
Mar 21, 2019 10:25 PM
señorEddie
Jun 14, 2016 09:53 AM
maclif
Apr 19, 2016 08:20 AM
circlecityrabbit
Feb 16, 2015 10:28 AM
moparman19
Sep 24, 2011 05:43 PM
