Diesel tachometer
Old Sep 21, 2000 | 08:14 AM
goody's Avatar
goody
Diesel tachometer
Sometimes while stopped at a light and the engine is idling at about 700 rpm, the tach will drop to about 400 rpm momentarily but the engine speed never changes. Is this just a bad sensor? Can it be cleaned or does it need replacing? Is it an easy job to change out? Or could it be the gauge itself?
Thanks for any replys....
Old Sep 21, 2000 | 07:31 PM
deleontow's Avatar
deleontow
Diesel tachometer
It could be either. The sender is located on the timing gear for the injector pump. It has two wires comming out of it. Check the sender and make sure it is not loose. Also check the wires and the conector. The sender works like a magnito sensing the teeth on the timing gear. If you pull it out, make sure the surface around the sender is clean as too not allow any dirt to fall into the gears. A little sand could be very destructive to the gears.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Sep 23, 2000 | 12:13 PM
alantbird's Avatar
alantbird
Diesel tachometer
theothewolf
Mar 27, 2017 03:08 PM
82_F100_300Six
6.7L Power Stroke Diesel
21
Jan 10, 2017 12:06 PM
Central Texcursion
Jul 3, 2013 06:37 AM
dozippy
1978 - 1996 Big Bronco
Aug 29, 2005 11:52 AM
munrow
Jun 9, 2005 08:19 AM
