1978 - 1996 Big Bronco
PULSING engine
Old Aug 28, 2005 | 08:17 PM
dozippy's Avatar
dozippy
PULSING engine
I just bought a 1989 with a 302 automatic. the engine pulses from about 500 rpm to 800 rpm it soundas annoying is this normal,,, the pulsing that is ?
Old Aug 29, 2005 | 11:52 AM
94 XLT White/ Silver 302's Avatar
The pulsing isn't normal, First off put a code reader on your engine and see if you have any codes. If not then I would spay some fuel injection into the throttle body and see it that helps, spray it down good while the engine is running. If that doesn't help clean the air bypass valve, or your throttle positioning sensor is bad.
patho44
Feb 23, 2007 02:12 AM
Madsan
Feb 5, 2007 08:08 AM
SWStanczyk
1983 - 2012 Ranger & B-Series
May 9, 2006 10:14 PM
mcne
Electrical Systems/Wiring
Feb 28, 2006 07:11 PM
traildawg
Mar 22, 2001 12:58 AM
