Sponsored by: Auxito
MPG expectations?
Old Jun 14, 2004 | 08:40 PM
  #46
openclasspro's Avatar
openclasspro
Originally Posted by Trek93023
I have a 98 f150 extended cab (4wd) with 16X10 wheels and LT315/75/R16 Maxxis buckshots. I have a 3.55 gear ratio. K&N air filter, and true dual flowmasters. I get 10.5 to 11 mpg in the city...is that the best I can expect to get. Would a chip help or would that make it worse?
Thanks
you have heavy *** whel tire combo- rotating mass is the worst- that and 3.55 cogs- gety 4-10's it will improve- id personally go 4.56's it would take alot of stress off your driveline
Old Jun 15, 2004 | 07:08 PM
  #47
Camille Marquis's Avatar
Camille Marquis
the pulleys were the best in my opinon but i have yet to do the exaust
The k+n filter test i did was to open the airfilter assembly remove the filter and start the truck then put the paper filter in place listen to the rpm s drop and come back then do same with k+n had no drop in rpm s tried it again with paper filter same drop now im convinced imagine the increase at high way speed
Old Jun 16, 2004 | 09:56 PM
  #48
KevinW's Avatar
KevinW
Exclamation Gears off
Thanks
Just remember your odometer is around 10% off. You are traveling more miles than you show so you need to correct for that when doing the math.
Old Jun 16, 2004 | 09:59 PM
  #49
Camille Marquis
go for under drive pulleys and then the everyone seams to go chip but chip needs 91 octane
Old Jun 17, 2004 | 02:10 AM
  #50
archer1's Avatar
archer1
This week i averaged 19-20 miles per gallon in my 97 XLT reg cab 4x4 4.6 and a 5 speed with 3.08 gears (they suck). fill up set odometer at 0 run 410 miles fill up set at 0 run and fillup 20.5 gallons with 419 miles on the odometer 20.4 miles to the gallon with 100.000 miles and no mods and oem plugs and wires.
Old Jun 17, 2004 | 07:55 PM
  #51
Camille Marquis
try some mods mabey you could get 25 wouldnt that be something
ascheperle
Apr 14, 2015 05:10 PM
Truck Guy99
29
May 8, 2014 10:09 AM
goose2
2004 - 2008 F150
15
Dec 20, 2006 08:41 PM
Fordman 0781
Apr 29, 2004 02:36 PM
Ultramagdan
1997 - 2003 F150
Oct 25, 2001 08:30 AM
