Does the Erson roller rockers have the end stands for support? Has anyone tried the Competion Cams 1046 hd kit (with end stands) or the std 1046 kit (without end stands)
The Erson's are made of two billet aluminium stands that support the entire shaft from end to end. They can handle 800lbs of spring pressure. Comp is way more expensive. I got the Erson's for 610.00.
i found a set of rollers in summit made by harland sharp. they come with the rockers and shafts for 319.00. has anyone used these before? just wondering because they seem to be a good deal and nicely made.
Thanks, the only place I know of to buy the doves is from www.dscmotorsport.com . The reason for the sound my truck makes besides the cam is the 3" tubing with the H-pipe. The next time I do it I am going to run 2 1/2" pipe with an X-pipe. I like the sound now but the neighbors aren't all too fond of it. They say their dishes rattle in their cabinets.
That's where I got my Doves from (DCS). Paid $570 for them, and that was without the end stands. Those would have pushed it up to about $700. Couldn't stand that!. That's one of the cool things about the Erson setup, you don't need extra end stands with them, it's all built together, I believe. And for a decent price too, compared to Dove and Harland. I'd definitely go Erson if I had to do it again, especially now that they're more available.
And Sean, I did the 2 1/2 with x-pipe, just FYI. Side exit right in front of rear tires. I'm pretty happy with that.
You can use stock shafts and stands with rollers. Everything fits just fine. The problem is with agressive, higher lift cams you will end up snapping the ends off of the shafts. I have broken 2. Putting end stands on stock shafts will remedy this problem.
Will the Erson rockers fit under the Lemans Cobra valve covers ? What pushrods should be used Running a 390 .040 flat top with 4 valve releifs hypertechtic pistons with edel heads, RPM intake, and RPM camshaft. Edel 750 carb. For my Ranchero. Thank Guys
Reason: forgot something
i don't think the valve covers will fit, if they are any designed like the factory ones they won't. comp cams makes a pushrod that would work with that cam and head combo, so does crane. the comp cams # is 7533-16
