Vehicle speed sensor needed?
Old Jun 7, 2004 | 05:53 AM
jeepnford's Avatar
jeepnford
I have an 87 FI 302 that was mated to an automatic transmission that had a vehicle speed sensor attached. I'm wanting to put it on an 83 T-18 manual transmission with a Dana 300 transfer case that doesn't have a provision for one. Is there a way to make this work?
Old Jun 10, 2004 | 12:25 AM
terryr's Avatar
terryr
Some people use EFI without the VSS. Some of them have no problems, while others have stalling when coming to a stop. VSS is also for factory cruise.
Old Jun 10, 2004 | 11:17 AM
loudfords's Avatar
loudfords
Hmm, is the VSS the little unit that piggybacked the speedo cable at the tranny or did it read the ring gear in the rear axle? If it was on the speedo cable, and your transfer case has speedo cable provisions, couldn't you hook it up that way?
Old Jun 11, 2004 | 05:40 PM
jeepnford's Avatar
jeepnford
The ford cable has a different attachment than the Dana T-case but did a little searching and found a place than can build custom ones.
skyfox10
Modular V10 (6.8l)
Apr 14, 2014 08:06 PM
edonop
Jan 15, 2013 08:47 AM
Kingfisher591
Sep 26, 2012 08:58 PM
bobfromktown
1978 - 1996 Big Bronco
Nov 5, 2007 03:11 AM
steve80
Nov 5, 2005 08:22 AM
