1978 - 1996 Big Bronco
Vehicle Speed Sensor
Old Nov 1, 2007 | 09:36 PM
bobfromktown's Avatar
bobfromktown
For the past couple of hours I have been looking for my vehcile speed sensor and I can't find it anywhere, it is not on the rear diff, that is the abs sensor, and I can't find it on the transmission or t-case, I have a 351-w, e4od, borg warner 1356 electric shift tcase.
Old Nov 1, 2007 | 10:04 PM
95bogginbronco's Avatar
95bogginbronco
That ABS sensor on your rear diff is your VSS. It serves both functions.
Old Nov 1, 2007 | 10:28 PM
bobfromktown
But all the auto part stores that I have been to said that it has an independent vss and rear abs is standalone as well, but I bought a rear abs sensor for the truck when I was at the Auto Store so is that what I need?
Old Nov 1, 2007 | 10:52 PM
andym's Avatar
andym
All the auto parts stores you have been to are wrong. They are one and the same in your Bronco. Yes, that's what you need.
Old Nov 2, 2007 | 12:07 AM
Mr. M's Avatar
Mr. M
Touche Andy! I don't have enough fingers to count the mistakes guys behind the counters make on part names, compatibility etc. etc.
Simply pickup the VSS/ABS combo sensor, and remind the misinformed retail clerk that his information needs some proofing.
Old Nov 2, 2007 | 08:26 AM
Kemicalburns's Avatar
Kemicalburns
rear abs sensor is what you need. ask for that and dont try to explain it to them. aint worth it
Old Nov 2, 2007 | 09:19 AM
95bogginbronco
I'm with those guys. The parts guy at the counter isn't always correct
Old Nov 2, 2007 | 12:26 PM
bobfromktown
Do you guys know the part number or any place I can possibly buy that 4x4 switch, it says 4x4/low range and his little tiny lights next to it. It goes inside the dash panel.
Old Nov 2, 2007 | 09:41 PM
THE KING's Avatar
THE KING
Bronco Grave Yard. You can find any switch or part you need for pretty good prices. broncograveyard.com
Old Nov 5, 2007 | 03:11 AM
greystreak92's Avatar
greystreak92
Hehehehe, I love stories like this thread... I wouldn't trust the guy behind the counter to know the difference between motor oil and Coca Cola if he TASTED it! But this is coming from someone who was told that there was no V8 available for his 92 Bronco because the guy looking up the injector part number didn't know the Bronco II and the Bronco were two different models and swore that the BII was the ONLY model available in 1992 and I had no idea what I was talking about!
No704
Jun 3, 2016 02:33 PM
skidmarks82
1997 - 2003 F150
Dec 7, 2015 09:47 AM
BigAl250
Mar 22, 2014 02:52 PM
1badshovel
May 16, 2011 11:19 AM
Goodold71
Mar 1, 2004 01:09 AM
