Too Much Load for Instrument Circut?
Old Jun 6, 2004 | 01:50 AM
Like M. Fords's Avatar
Like M. Fords
I will be adding 6 Autometer gauges to my '69 F250, and plan on lighting them by tapping into the original instrument lights so that I can dim them all together if necessary. The Autometer gauges use GE 161 bulbs. I lit all 6 of them together in parallel and they appear to draw less than an AMP--probably closer to half an AMP. Do you think I will taxing the headlight switch and/or rheostat too much?
Old Jun 6, 2004 | 03:47 PM
Franklin2's Avatar
Franklin2
Will probably be ok. If you are like me, I leave the dimmer control wide open anyway, because I can't half see the guages at night. So in that case, you are not using the dimming resistor at all.
regidog
Mar 19, 2017 04:56 PM
F350moneypit
Jan 17, 2013 08:29 AM
rupejosh
Dec 16, 2008 08:46 AM
Ultraute
Electrical Systems/Wiring
18
Jul 12, 2006 09:22 PM
moonley
Aug 14, 2003 04:03 PM
