What kind of tranny fluid for a c-6 - 1969 f250
Old 06-06-2004, 01:32 AM
eandaauto's Avatar
eandaauto
eandaauto is offline
What kind of tranny fluid should I run in my 1969 f250 with the c-6? When I bought the truck the fluid was changed and dexron was used. The tranny slips going into 2nd gear. Should I drain it all and change it back to f?
Old 06-06-2004, 11:37 AM
jds1971's Avatar
jds1971
jds1971 is offline
There's those that will tell you that you should run Type F (Ford's recommendations at the time the truck was produced) no matter what. It's my belief that if the tranny hasn't been rebuilt recently, you should have Type F in it. If the tranny has been rebuilt recently, then Dexron will be just fine. The reason I say this is because the materials used when building today's clutches and bands are compatible with Dexron.
If your trans is slipping now, it may already be too late. You could try draining the Dexron out of it and putting Type F in, but the band and the clutches are already impregnated with Dexron and if they have been slipping for a while, then they are most likely glazed and different oil may not help. How is it from 2nd to 3rd? You might try adjusting the band and see if that makes any difference.
Good luck-
Joe
Old 06-11-2004, 08:24 PM
Fattydaddy100's Avatar
Fattydaddy100
Fattydaddy100 is offline
I had the same problem. I had someone dump dexron into my tranny, and it slipped. I was told to change it back to type F and it worked. Seems to use more fluid, but the type F did the trick. Just drain the torque convertor also, and make sure as much fluid comes out as possible. Good Luck -Fatty
Old 06-11-2004, 08:40 PM
RapidRuss's Avatar
RapidRuss
RapidRuss is offline
FE "Freakin Expensive"
Dexron will foam at ford temps..and pressures... If you didnt try to hot rod it ..you should be OK..
Always use type F with the ford trannies...it has an anti foam agent in it,so the fluid stays as a fluid and not Bubble's... Russ
Old 06-12-2004, 06:40 AM
trike1946's Avatar
trike1946
trike1946 is offline
I ahve a 79 with 242K. Original trans. It was my uncles. He used type F so I kept doing it too. Still works fine. Changed fluid every 25,000. I have been told B & M makes something called "Trick shift". Sold in Pep Boys. Also supposed to work well, but pricey.
Pitcrw6
06-10-2012 08:07 PM
1969furd
01-19-2010 11:01 PM
hotrrod69
Engine Swaps
04-10-2006 07:19 PM
michaelbrainardatwor
04-02-2004 03:07 PM
76390FE
12-11-2003 12:57 AM
Quick Reply: What kind of tranny fluid for a c-6 - 1969 f250
