gear shift indicator not correct
Old Jun 8, 2004 | 05:57 PM
New-retired-man's Avatar
New-retired-man
have auto transmission on f 250 superduty, 1999, what do I have to do to get to indicate correct position. Drive shows 2nd gear for example. Wanting to see if I can fix myself.
Old Jun 8, 2004 | 08:21 PM
mhg's Avatar
mhg
remove lower dash panel
move shifter and you will see a string attached to
the shift column
there should be a screw holding it in place
you can adjust it at that point
Old Jun 12, 2004 | 09:28 AM
New-retired-man
thanks
Will check out this weekend , thats for your help.
