need help removing valve springs
Old Jun 5, 2004 | 08:09 PM
fordeverpower's Avatar
fordeverpower
I bought a hook type spring compressor to take out some valves but I don't know what to do when the spring is compressed. I don't have a single retaining plate and I can't get the locks out. I am not sure what i am supposed to do. I looked at steve christ book and the head had a 1 piece retainer and i don't. Anybodyknow what i need to do or what I have?
Old Jun 5, 2004 | 08:10 PM
fordeverpower
Am some checking I guess its a retainer sleeve that i need to figure out. But what do i do?
Old Jun 5, 2004 | 08:12 PM
Ratsmoker's Avatar
Ratsmoker
What kind of compressor are you using? Does it slide into the top and bottom of the spring (very bad design) or does it look kind of like a c-clamp that squeezes the top of the spring and the bottom of the head?
Old Jun 5, 2004 | 08:18 PM
fordeverpower
its the el cheapo that hooks into the top and bottom of the spring. I am using a c clamp to hold the valve.
Old Jun 5, 2004 | 08:21 PM
Ratsmoker's Avatar
Ratsmoker
Compress the spring and retainer together and then give the valve face a soft tap with a rubber mallet or wood dowel. This should bring the lock up and out of the retainer. The locks should easily come off after that.
Old Jun 5, 2004 | 08:25 PM
fordeverpower
Originally Posted by Ratsmoker
Compress the spring and retainer together .
Thats not possible with the compressor I got!!! It only compresses the retainer but not the retainer sleeve.
Old Jun 5, 2004 | 08:58 PM
GLR's Avatar
GLR
Are the heads off? What I do is take a deep 1/2" drive socket which will match up to the inner retainer, and hit it a few times with a hammer..not real hard but they do wedge in there. Then when you comp the spring, you might have to take a straight punch and tap the retainer loose. It also helps to have a small magnet handy for the keepers.
Old Jun 5, 2004 | 09:31 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
OK ford let me see if I have this right? the bottom of the compressor goes to the valve face...and the top compresses the spring..it pushes down on the retainer right?
after you compress the retainer and sping together at the top of the valve stem you will see the retaining clips..tap on them..there in 2 halfs the should fall off.. remove them..and then slowly let the tension off the compressor..I have seen springs take off
Like rockets.. Hope this helped? Russ
Old Jun 5, 2004 | 09:32 PM
Ratsmoker's Avatar
Ratsmoker
What do you mean by retainer sleeve?
Old Jun 5, 2004 | 09:36 PM
fordeverpower
Thats what my budy Tom monroe called them. I used a 3/8 drive 9/16 socket and got it out. And as someone said i used a magnet. I hate the stupid compressor and I plan on going to town tomorrow to get the better clamp style one. I wanted that one from the start but cheaped out on one from carquest. The one I got is a complete pain in the ***.
Thanks guys!!!
RapidRuss's Avatar
RapidRuss
Sean..he may have a cup that goes upside down over the top of the spring below the retainer? Some of the old one's did...
Old Jun 5, 2004 | 09:43 PM
pops_91710's Avatar
pops_91710
I used to use a large 1/2 inch drive socket to get the valve springs off. I set the socket centered on top of the spring retainer, whacked it with a heavy peen, and that compresses the spring. The split retainers fall off and the valve is free!
Of course you'll still need a spring compressor tool to put them back on.
Redneckfordf2502002
Nov 27, 2014 11:16 AM
79sparky
Jul 15, 2012 03:14 PM
1995sho
May 11, 2009 08:40 AM
Fords&Farmalls
Jun 19, 2007 09:13 AM
jwtaylor
Jan 13, 2004 09:27 AM
