Valve Removal Problems
Old Jun 18, 2007 | 10:57 PM
Fords&Farmalls's Avatar
Fords&Farmalls
Hello
Tonight I was trying to take out the valves on my 352 out of a 1965 F-350. When I compress the valve springs, I cannot get the valve retainer lock washer thing (name?) or the valve retainer out. Is there some sort of trick to doing this? I dont know if all valve retainer assemblies are basically the same, but on mine, the lock washer on it is actually 2 pieces around the valve stem. Do you have to hold the valve up and push the valve retainer down after you compress the spring to get the valve retainer lock washer off? My chilton doesnt help at all, it just says "compress spring and remove valve retainer lock washer and valve retainer" so I am assuming it should be simple. Any help would be greatly appreciated.
Thanks
Garrett
Old Jun 19, 2007 | 05:25 AM
garbz2's Avatar
garbz2
Nothing like stuck FE keepers. (the two piece thingies)
A old mechanics trick is to tap the valve head sharply with the wooden end of a hammer while holding on to the valve spring compressor. I then use a daub of white lith grease on my finger tip to capture the little buggers.
The grease does a decent job of putting them back in too.
Garbz
The oils varnish and oil sludge makes for a good glue.
Old Jun 19, 2007 | 05:32 AM
ford390gashog's Avatar
ford390gashog
First make sure you have the valve compressed enough you need about 3/16'' of compression at the valve keeper to remove it. Try tapping it with a wood hammer or a brass one.
Old Jun 19, 2007 | 09:13 AM
Fords&Farmalls
Ok, I understand now. Hopefully I'll have time soon to do it.
Thanks
Garrett
queen of spades
Oct 12, 2013 03:45 PM
crescentwrencher
Jun 2, 2008 08:45 AM
fordeverpower
Jun 5, 2004 09:43 PM
dmptrkr
Flathead V8 & Flathead 6
May 12, 2004 10:46 AM
longjohn69mustong
May 10, 2004 06:37 PM
