Oil pan question - front or rear sump?
Ok, i have read in several places that a rear sump oil pan is a must for off-road use because a front sump will not hold oil on the pickup screen when going up hills. So my question is will a rear sump go dry going down steep declines? Ive never been wheelin where i go down or up a hill without doing the opposite on the other end. I have a 78 F-250 with a 6" skyjacker lift and the motor im puttin in it is a 460 from a 68 Lincoln with a front sump. Currently with the 400 sitting in it there appears to be plenty of room in it for a front sump pan an if my diff would hit the pan i am gonna have more to worry about than the dent in the bottom of my oil pan. Not to mention the cost of those oil pan swap kits, I would rather spend it on a centerforce clutch or a better radiator. Any comments or sudjestions would be welcome. Thanks
Originally Posted by wvmudder
will a rear sump go dry going down steep declines? I have a 78 F-250 with a 6" skyjacker lift and the motor im puttin in it is a 460 from a 68 Lincoln with a front sump. Currently with the 400 sitting in it there appears to be plenty of room in it for a front sump pan an if my diff would hit the pan i am gonna have more to worry about than the dent in the bottom of my oil pan. Not to mention the cost of those oil pan swap kits, I would rather spend it on a centerforce clutch or a better radiator. Any comments or sudjestions would be welcome. Thanks
You can also use a 8 quart rear sump pan from a 370 or 429 truck motor. I have one on my 78 with no lift and it clears everything. I bought it for $50 from a truck salvage. What ever pan you use be sure to get the correct pick-up for it and make sure it doesn't sit on the bottom of the pan.
Doesn't matter. What!? Sacrilige? Nope. All you need is a high capacity pan with baffles around the pickup to keep the oil around it at angle. The real slick jobs will have trapdoor baffles. You can either buy them like that (my canton is a front sump with trap door baffles, a windage tray, and crank scraper and will keep the oil around the pickup at every angle except upside down) or you can weld them in yourself.
marchettej
15
08-26-2014 12:08 AM
93truck
11-04-2010 10:27 PM
JermKline
06-10-2006 06:53 PM
