77 f150 4x4 351m oil pan question
My boy bought this truck to restore for his first car. my question is, the oil pan leaks like crazy and needs replacing. its a 351m standard shift. The pan looks like it was replaced before and looks like the dip stick was added to the side of the pan. the pan that is on it has the sump (deep part of the pan toward the rear of motor), the dip stick now is in the drivers side by the exhaust manafold but its shot. I thought that it should be behind the ALT in front of the valve cover on pass. side. Thats where mine is on my 351c motor. there is a hole there for one. The big question is what kind of pan should be on the truck. A front sump pan or rear sump pan. I think that if the dipstick is in the front then the sump should be in the front. I dont know anythnig for sure. any info on this will help me alot when i order a new one. if i have to change the pan to a front sump then i will also have to change the oil pick-up tube for the oil pump i would assume.
thanks
thanks
BEN WHEELAN
11-04-2016 06:54 PM
marchettej
15
08-26-2014 12:08 AM
