Brake warning light
Old Jul 2, 2013 | 08:40 PM
Duckmang's Avatar
Duckmang
Brake warning light
I have a red "Brake" warning light illuminated in the cluster of my 75 HighBoy. The diagrams show a "Low Brake Switch" but there isn't anything on my master cyl or parking brake. Any ideas?
Old Jul 2, 2013 | 08:54 PM
co425's Avatar
co425
Follow the master cylinder lines down to the frame. There should be a proportioning valve there. The brake warning switch is on that prop valve. That light activates when you have a pressure differential in the lines front vs rear.
Old Jul 2, 2013 | 09:13 PM
Duckmang's Avatar
Duckmang
Sure'nuff. Danged near invisible, but its there. The brakes felt ok the little bit I drove it to get it home, may just start by pulling one at the junkyard to swap. It sits pretty close to the headers. I'm thinking the heat might have killed it.
Old Jul 3, 2013 | 01:13 AM
co425's Avatar
co425
That's possible. Or you have a leak somewhere. 33 year old plus rubber lines tend to do that.
Floggit
Mar 29, 2015 02:14 PM
silar
Sep 22, 2014 09:59 PM
andrewasl
Aug 18, 2005 12:08 PM
cigarxtc
Mar 21, 2005 04:54 PM
1969FordF250
Electrical Systems/Wiring
Apr 9, 2004 03:18 PM
