Engine Number Decode
Old Nov 24, 2007 | 02:07 PM
Beanscoot's Avatar
Beanscoot
Hi Bill,
That's interesting about the 1977 Lincoln Versailles using a special crankshaft (D74Y-6303-A), and cylinder block (D74Y-6010-A).
Are these parts functionally interchangeable with the other engines? Do you know if these parts are better, worse, or the same?
Do you know the casting numbers associated with those part numbers?
Old Nov 24, 2007 | 10:02 PM
baddad457's Avatar
baddad457
The Lincoln Versailles block's casting numbers are D8VE-6015 (dont recall the suffix) This block is a little known treasure, it's built thicker like the Mex block, but lacks the Hi-Po main caps. Bare weight for this block is 135 lbs. A late 80's roller block is 126 lbs. I just let one go to a friend that's into dirt track racing. He confirmed what Ford's 5.0 book said about it, he inspected it all over and found it to be thicker everywhere over all the other production blocks exepting the Mex block. The Lincoln block has a boss cast in the rear for a crankshaft position sensor, thus the reason for the part number difference. The sensor was for the electronic feedback carb.
Old Nov 24, 2007 | 11:12 PM
Beanscoot's Avatar
Beanscoot
Hey Baddad, thanks for that info. Now the cat's out of the bag, however, so those blocks will be snapped up (well maybe not) fast now. I imagine the cranks also have some provision for the crank trigger which is what makes them unique.
Or maybe they're a 4340 forging? [Humour]
Old Nov 25, 2007 | 09:12 AM
baddad457's Avatar
baddad457
I don't know what's different about the crank, the block I had was pulled from a 67 Stang I'd bought a few years ago.
Niwrek
Sep 24, 2023 05:53 PM
wfo1955
13
Mar 22, 2017 09:38 PM
cat56
Sep 30, 2006 08:23 PM
fordbuilder
General Automotive Discussion
Mar 1, 2005 10:45 PM
lr
May 27, 2002 08:17 AM
