honk honk
Old Jun 1, 2004 | 07:42 PM
ron96xlt's Avatar
ron96xlt
honk honk
need help with a no working horn, wired directly to battery and horn works, where is the relay and or switch? Thanks
Old Jun 1, 2004 | 08:38 PM
trojanman25's Avatar
trojanman25
its probably a bad fuse, unless you checked that.... check it before worrying about a relay.. or switch...
Old Jun 1, 2004 | 08:54 PM
Ken00's Avatar
Ken00
You should have a relay in the battery junction box. When the horn button is pressed the relay is grounded through the airbag sliding contact. When this happens the relay closes and the horn goes HONK. Both of these circuits are powered from the same fuse and connection to the relay.
Old Jun 1, 2004 | 09:11 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Another common horn problem is that the single wire horns (prior to 98 I think) ground through the attaching stud. Rust and time create a poor ground through the painted fender inner. Try running a ground directly from the horn attaching stud to the battery or a known good grounding location.
Old Jun 1, 2004 | 09:56 PM
hreed's Avatar
hreed
My 95 has a horn relay in the power distribution box under the hood. It is the same type of relay to run the wipers. I know, because now my wipers work, but the horn is inop, and I haven't gotten around to replace it yet. If it's not a bad ground, my guess is the relay. Try swapping the horn relay with a wiper relay to see if it works. They are small black rectangular boxes at the front of the distribution box and should be identified on the lid. If that is the problem, don't be lazy like me! Replace the relay.
Old Jun 2, 2004 | 02:38 PM
atvchick's Avatar
atvchick
I have a question about the horn too. On my boyfriends 01 ranger when you push the horn there is only a clicking sound. I think it comes from the dash on the passengers side or close to that area. Also, where is the horn located under the hood? thanks
Old Jun 2, 2004 | 03:31 PM
Ken00's Avatar
Ken00
Try the inside of the front drivers fender well or on the radiator support.
Old Jun 2, 2004 | 04:18 PM
ron96xlt's Avatar
ron96xlt
thanks...will proceed and let you all know.
Old Jun 3, 2004 | 05:52 PM
ron96xlt's Avatar
ron96xlt
problem solved ......$9 horn relay, you guys are #1
Old Jun 3, 2004 | 08:11 PM
Ken00's Avatar
Ken00
Glad to hear your honking again.
Velocity2
Nov 27, 2014 02:49 PM
garrinmarie
2004 - 2008 F150
Jan 28, 2011 01:08 AM
Ripbc
Nov 5, 2006 03:27 PM
blk964xbronc
13
Jan 3, 2005 03:04 PM
BOBBY MCCULLEY
Sep 22, 2004 09:15 PM
