Throttle Pressure Adjustment
Old Jun 1, 2004 | 07:28 PM
Jimmy Dean's Avatar
Jimmy Dean
How do I adjust throttle pressure one a 92 150? 302 w/ AOD tranny....4x4 if that matters any
Old Jun 2, 2004 | 05:14 PM
Jimmy Dean's Avatar
Jimmy Dean
help?
please
Old Jun 2, 2004 | 05:37 PM
the_hetz's Avatar
the_hetz
Old Jun 2, 2004 | 07:09 PM
Jimmy Dean's Avatar
Jimmy Dean
VERY hard....extremely....like tryin to put foot through the floor.
Old Jun 2, 2004 | 07:20 PM
92lightning's Avatar
92lightning
Is the Throttel body sticking or is the cable need lubercation? My Throttel body sticks when it's dirty and the pedal acts stiff. SAV
Old Jun 3, 2004 | 06:11 AM
SoFla David's Avatar
SoFla David
well, it could be many things, from the spring on the pedal, to the throttle cable, to the spring on the Throttle body, to the throttle body itself.
I would reccommend disconnecting the cable from the throttle body. Then push on the pedal to see if it is still hard. Then you can start to isolate where the problem is.
I ended u cutting a few coils off the spring at the end of the throttle cable (the side that connects to the throttle body) and now it is a little softer. Just make sure you don't cut too much so the throttle still returns to idle when you take your foot off the pedal.
Old Jun 3, 2004 | 12:53 PM
Jimmy Dean's Avatar
Jimmy Dean
ok tanks, the TB has been replaced already. but I will start gettin this done, it is not my truck a friends and we are working on each otehrs trucks right now tryin to get mine running and his to where he likes it.
kailor
May 29, 2012 11:18 AM
payday33
Mar 22, 2012 09:59 AM
austin2466
May 28, 2009 07:46 AM
eatfish
Feb 5, 2009 06:21 PM
WALJON
Jul 21, 2007 08:12 AM
