AOD questions
Old May 27, 2009 | 11:48 PM
austin2466's Avatar
austin2466
AOD questions
Is the TV pressure valve one of the three holes on the passenger rear side? Which one exactly? And on the pressure gauge it should read 0-10 psi at idle and just go up as the throttle increases ya? The throttle lever should be at WOT before the TV lever right? Really just wondering which port to use. Thanks.
Old May 28, 2009 | 12:13 AM
85e150's Avatar
85e150
Instructions here if this link is clear enough:
http://www.tciauto.com/Instructions/Instructions.aspx
After you get there, open up "browse by product type" and 'Ford TV Cable...' will be an option.
Hope that helps.
Old May 28, 2009 | 07:46 AM
l-m tech's Avatar
l-m tech
there is a gauge block that you will need to set the tv pressure with.
