AOD throttle valve pressure
Old Mar 13, 2012 | 08:11 AM
payday33's Avatar
payday33
I put a used AOD in my 1981 F 100. The throttle valve seems to be binding up even with the linkage disconnected. There is no pressure on the TV port. The truck will move in all gear positions, but it will not shift.
Thank you
Old Mar 13, 2012 | 11:48 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/5...ng-aot-tv.html Have a read here, may help.
Old Mar 13, 2012 | 04:38 PM
payday33's Avatar
payday33
You can't set the pressure if there isn't any pressure to set. Zero pressure, nothing comes out the hose if I remove the gauge. Changing the position of the throttle valve linkage arm on the transmission doesn't change anything.
The throttle valve is probably stuck. It is very hard to move manually.
Old Mar 22, 2012 | 09:59 AM
payday33's Avatar
payday33
The inner throttle lever had slipped and was stuck between the valve plunger and the case. The push rod was pushed in and jammed. I was able to loosen the outer throttle lever, pull it out, and extend the push rod. The levers work good now and the transmission shifts.
LARIAT 85
'80-'86 HOWTO's
34
Jun 6, 2026 11:08 PM
bcamill
Nov 24, 2017 10:07 AM
austin2466
May 28, 2009 07:46 AM
eco
Jan 31, 2006 03:33 PM
Jimmy Dean
Jun 3, 2004 12:53 PM
