Fpr
Old Jul 17, 2007 | 08:55 PM
WALJON's Avatar
WALJON
Fpr
HELLO what will I gain if I shim my FPR
Old Jul 17, 2007 | 09:15 PM
wreckit72's Avatar
wreckit72
You will get higher fuel pressure.
Old Jul 17, 2007 | 09:47 PM
tjbeggs's Avatar
tjbeggs
better throttle response is the main attaction
Old Jul 18, 2007 | 04:38 AM
Neal 97 250's Avatar
Neal 97 250
You probably won't notice the difference but maybe throttle response as tim said.
Old Jul 20, 2007 | 10:04 PM
WALJON's Avatar
WALJON
Thanks, not worth it then?
Old Jul 20, 2007 | 11:28 PM
10bands's Avatar
10bands
The main reason for shimming the fpr is that the spring in there can get weak over time resulting in low pressure. If it is low then sticking a bb in there will bring it back up. Somebody correct me if I'm wrong but ideally you want it to be around 70 psi. If your pressure is down in the 50's or worse it needs it.
It has been used as supporting/performance mod up around 80+ psi but that is not recommended unless you really know what you're doing. Very simple to do. Takes about 10 minutes.
Old Jul 21, 2007 | 08:12 AM
tjbeggs's Avatar
tjbeggs
Ryan Bean (Bean Diesel Performance) recommends no more than 65 PSI. If it is lower there than that shim it to get it close to that.
10bands is right if your pressures are low. I would say lower than 60 I would shim it shooting for 65-70 as ideal.
OBSEnthusiast
Oct 7, 2015 11:24 AM
JRogersOU
Aug 8, 2014 04:26 PM
Jaime Herrera
Oct 5, 2012 09:13 AM
3wildboys
Nov 8, 2011 01:32 PM
arecycling77
Jan 18, 2011 09:40 PM
