ultimate c6
Old May 31, 2004 | 07:56 PM
superswamper's Avatar
superswamper
ultimate c6
i'm feed up with my transmission not hooking up, i understand i do have 36's i haven't re geared for but i put the shift kit in and it still makes the slipping "swhiiish" under hard acceleration. So i'm building the stoutest c6 possible, the list so far includes: low gear set, 5 pack sprag (7 if its out there), full manual valve body and code r servo and low drag planetaries and kevlar this and that. but the reason for this post is what other parts can i do to improve the tranny besides what comes in the "super" rebuild kits?
Old May 31, 2004 | 11:52 PM
mark a.'s Avatar
mark a.
Dont forget the shift levers. I run a L servo & a E shift lever.
Old May 31, 2004 | 11:54 PM
superswamper
so an e shift lever is the hot ticket?
Old Jun 1, 2004 | 12:19 AM
mark a.'s Avatar
mark a.
HHHHMMMM that depends on a lot of things.
Old Jun 1, 2004 | 12:34 AM
superswamper
what does the e shift lever typically come in?
also what exactly does a transbrake do?
is it just a reverse line lock on the valve body?
Old Jun 1, 2004 | 12:35 AM
superswamper
what would it depend on ?
Old Jun 1, 2004 | 12:28 PM
mark a.'s Avatar
mark a.
A trans brake basicaly binds up the trans on the starting line so when the light goes on its ready to go with a lot of force. They arent easy on things either. They would be of no practicle value in a 4x4.
A shift lever multiplies the pistons apply force to the band. a E lever has a 2.18 ratio it squeezes the band tighter around the drum. Shifts get more firm with higher ratios but at some point the shifts will start to slow down. It takes some experimentation to get it right for your aplication.
Maby try B&M for one. Selecting one will depend on what servo you want to use.
Old Jun 1, 2004 | 12:57 PM
superswamper
i apperciate the help mark, basically what i'm trying to do with this truck is turn it into a mud racer, i've got a pretty healthy engine (450+ hp) and i want the stoutest tranny i can get behind it, still being an auto. its basically going to be a off road drag racer, so i'm hoping to get every last bit of performance out to the ground with this tranny. i plan on doing the "r" servo, so i was thinking the e lever would be the way to go? i've been hunting around a noticed some extra wide "power bands" that are an 1.5 wider than stock, also found an 8 disc clutch pack would any of this effect the shifting?
http://www.transmissioncenter.net/C4_C6.htm this is the place i found alot of the stuff.
also noticed they had an aluminum e lever on there
Tyaz92
Oct 31, 2014 09:07 AM
jdgoodnite
Jun 14, 2012 04:28 AM
82f100460
Jun 10, 2012 08:22 PM
scottfreeman
Apr 5, 2011 02:19 PM
low springs
34
Apr 13, 2005 03:43 PM
