Charging A/C system on 98 Expy
Old May 31, 2004 | 06:02 PM
jakermc's Avatar
jakermc
I intend to charge the system with one of those R134a cannisters and wanted to make sure I understood where the low pressure service valve was before I do anything silly. I'm not familar with the A/C systems so excuse my ignorance.
It seems as though the HIGH pressure valve is the black cap covered outlet just to the right of the windshield washer reservoir? If this is true, the only thing that looks like the LOW pressure service valve is the little outlet that is sticking out of the right side of the round cylinder (this is a technical term) located behind and under the main battery fuse box. Its attached directly to the cylinder looking thing as opposed to being attached to a line, like the other valve is.
Do I have this right? Anyone have a picture of this?
Old May 31, 2004 | 10:06 PM
xcopterdoc's Avatar
xcopterdoc
they are different sizes... you cant fit the hose for low side on the high side.
Old Jun 1, 2004 | 05:58 AM
jakermc's Avatar
jakermc
That would confirm I am correct about the high pressure port. Did I identify the low pressure port correctly?
Old Jun 1, 2004 | 09:02 AM
xcopterdoc's Avatar
xcopterdoc
There are only 2 ports. A high side, which is the large connector and the low side which is smaller. Also look at the lines.. the high side line will always be smaller than the low pressure side line. I believe the round thing you are talking about is the reciever drier.. if it has a port on it, this will be your low side. As I said, the low side hose fitting will only go on the low side. You cant mess it up.
Old Jun 1, 2004 | 02:28 PM
buzzard's Avatar
buzzard
Yes, you did.
Old May 6, 2008 | 07:13 PM
deanjet's Avatar
deanjet
...If this is true, the only thing that looks like the LOW pressure service valve is the little outlet that is sticking out of the right side of the round cylinder (this is a technical term) located behind and under the main battery fuse box. Its attached directly to the cylinder looking thing as opposed to being attached to a line, like the other valve is.
I just ran across the same problem, Ford didn't make it easy to service the A/C did they
Old May 7, 2008 | 02:42 PM
deanjet's Avatar
deanjet
Pictures to help find the low pressure A/C service port
Click to enlarge
Old May 8, 2008 | 03:03 PM
MisterCMK's Avatar
MisterCMK
Yuck, that doesn't look like fun at all to get to. Great pics!
Old May 8, 2008 | 08:43 PM
starmonkey's Avatar
starmonkey
Deanjet you are the man. That is the best picture documentation on finding the low pressure valve. Nice work, I have been searching for that info for two days now. Thanks
Old May 9, 2008 | 07:43 PM
deanjet's Avatar
deanjet
The Easter Bunny hid that port!
Mr. Spidey
1997 - 2003 F150
Jun 13, 2017 10:33 PM
Dirtscooter250
Jun 9, 2016 09:13 PM
warren561
Apr 2, 2013 04:31 PM
tfmech
19
Aug 23, 2011 12:52 AM
Ultramagdan
Jun 27, 2008 05:51 PM
