Sponsored by: Auxito
1998 ford F150
Old Jun 4, 2017 | 06:00 PM
Mr. Spidey's Avatar
Mr. Spidey
1998 ford F150
I attached the A/C pressure gauge to the low pressure valve and the needle moved to the red area which reads 'may have chemical issues'. I then proceeded to inject the refrigerant which would not fill into the low pressure valve. Any suggestion as to what I can do to address this possible chemical issue?
Old Jun 6, 2017 | 08:18 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Just asking, is the engine and A/C compressor running? It will take about 30 mins to empty a can if you are at idle. It will run faster if you keep it around 2K rpm's
Old Jun 7, 2017 | 07:17 AM
formerjeepguy's Avatar
formerjeepguy
In the red? The engine is running and the AC is on? You should never try to add refrigerant if you are in the red.
What is the pressure reading? Are you sure you are connected on the low pressure side?
Old Jun 13, 2017 | 09:01 PM
Mr. Spidey's Avatar
Mr. Spidey
Yes, in the red. Which reads 'may have chemical issues' (as stated in the opening thread).... and it only fits on one valve, _ low pressure.... I'm just gonna change compressor. That is the answer I was looking for. This site is no help! smh
Old Jun 13, 2017 | 10:33 PM
Sam I Am's Avatar
Sam I Am
Did you short the low pressure switch? If it is short cycling it won't run long enough to draw in refrigerant.
WhoIsJohnDoe
May 3, 2018 12:50 PM
clevelandtundra
May 7, 2013 07:49 AM
provosc
Mar 12, 2010 09:03 AM
leftystar
Aug 1, 2006 05:52 PM
jdaniel73
Jul 3, 2005 09:13 AM
