1978 - 1996 Big Bronco
Problem pulling codes from '87 Bronco
Old May 30, 2004 | 08:44 PM
daddydcs's Avatar
daddydcs
Hey yall, I have been trying to pull codes on my 87 Bronco 302 with no luck. I followed the instructions found at fordfuelinjection.com which consists of grounding out the STI plug (the single prong plug) and turning the switch to 'On' position. When I do this the engine light comes on, but does not flash or blink or anything. I do hear the fuel pump prime and a relay click (like the ffi.com page says) but no blinking/flashing! If I remove the ground while the switch is still on then I get another click or two from a relay. Can anybody help me out on this one? I ran the ground to the battery to ensure a good ground.
Old May 31, 2004 | 08:12 AM
daddydcs's Avatar
daddydcs
Anybody have advice?
Old May 31, 2004 | 08:24 AM
AYoungblood's Avatar
AYoungblood
On my 90 there is 2 plugs and you have to connect that single prong plug to the top left plug spot; it looks like this ---
And then the check engine light will flash.
Good luck!
Adam
Old May 31, 2004 | 08:57 PM
daddydcs's Avatar
daddydcs
Thanks Adam, is your second plug kind of Trapezoid shaped like below?
_______
|________|
Old May 31, 2004 | 08:59 PM
daddydcs's Avatar
daddydcs
Oops, that didn't post like it showed in the window! see below (just ignore the 0s)
000000_________
00000/000000000\
0000|___________|
Old May 31, 2004 | 09:18 PM
Lookinfurfun's Avatar
Lookinfurfun
http://www.broncodata.com/tech/codes.htm
Old Jun 3, 2004 | 04:11 AM
daddydcs's Avatar
daddydcs
Ok, on Fordfuelinjection.com, they said to just ground out the STI (single plug). As mentioned above, that didn't work. Ayoungblood, I see that on yours you connect the STI to the top left prong on the output plug. Lookinfurfun, the link you posted shows connecting the STI to the top right prong. Does anyone know for sure which one to connect to? I'm afraid if I hook to the wrong one I could mess something up! Maybe the differences are for different year models? Mine is an '87 302. Thanks.
Old Jun 3, 2004 | 08:51 PM
Lookinfurfun
I use the method described on the broncodata site. If you have a Chilton's manual, the same method is described in there. I think Ryan at FFI just missed one step in there.
Old Jun 4, 2004 | 12:51 AM
Norm Carter's Avatar
Norm Carter
So you are using the "count the blinks" method, not using a code reader, right? There are lots of good posts about that in the old posts on this site.
Myself, I have an attention span of a cocker spaniel so I popped for the code reader at Wal Mart. It runs the continuous self test (codes in memory), KOEO and KOER tests, even speeds up the rpms at the right times in the KOER test. . Gives codes on an LCD readout. Well worth the bucks!
Old Jun 4, 2004 | 04:10 AM
daddydcs's Avatar
daddydcs
What did it set you back? Walmart carries them now? Man, they have everything!
95F350XL
Nov 30, 2012 03:55 PM
BandVan
Aug 17, 2012 04:53 PM
john165
Jul 21, 2012 06:09 PM
marcus1977
Sep 21, 2007 02:08 PM
rescuedranger
Sep 28, 2006 08:49 PM
