Been street rodding my 56F100 big window & am amazed how many major faults there are with the cab.
This truck must have been put together on Monday morning by a guy with a major hangover.
The truck looked like it was leaning & the pass. door had a large gap at the top of the door, after a lot of measurements I figured the drip rail was a full 1/2" high from the center line at the front all the way to the back of the cab. I cut the rail loose & rewelded it at the proper height. It was a lot of work but at least now the truck looks straight.
Door margins are really bad I have had to cut the door edges at the front of the doors for clearence to stop paint chipping & had to add 3/8" to the top of the drivers door to get a decent margin there.
The doors fit so bad that the top of both doors were only 1/4" above the
door header so I made a new channel to weld to the cab to bring the height down so there would be good contact with the weather stripping.
It required a channel shaped metal filler that was 7/16" on the outside edge of the cab to 1/4" on the inside edge.
I know the fit & finish on 50s cars was not very good but this truck is a real mess. Aw well it keeps me busy & out of trouble.
Back to top
Display posts from previous: All Posts1 Day7 Days2 Weeks1 Month3 Months6 Months1 Year Oldest FirstNewest First
I have a similar gap at the top corner of the driver door and a tight gap along the leading edge as well. I thought it was justa matter of getting the right weatherstrip. The previous owner packed the door with rubber sealer from home depot. Oh man...
the fifties cars were just as bad.quality control was unheard of.a friend talked to a guy who worked at ford in 56 and asked him how they adjusted the doors.we slamed them and if they shut it went through.
I have this same problem on my 52 and after measuring every absolute angle, I found that the cab was actually twisted, welded together with a twist in it. So i've decided to bring out the spot weld cutter and start all over where the factory should have left off.
