I had my dealer run an Oasis report on the VIN . it will give you the actual build date for the truck....Mine was built 1/21/04 and was purchesed on 3/5. have 7500 miles on it as of today and is running great...
Look for a white sticker (tag) on the drives side valve cover. On it
is the buiuld date of your motor
This is weird...I showed my neighbor the sticker on his motor and the date is there....mine just has the big white sticker with a bunch of #'s but no date....wat up wit dat?
Or go over to http://6literpowerstroke.flatratetech.com/ Message Forums. Register and login. They have an OASIS section just for running your VIN and tell them what info you are looking for.
I understand from earlier posts that date on the door post is the date the truck was assigned that VIN. I was told by the service advisor who ran my OASIS that my build date on the truck was April 2, 03, engine build was March 27, 03. The date on my door post is April 3, 03. So it is close enough.
