Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
scanners?
Old May 27, 2004 | 06:14 PM
carpe_diem's Avatar
carpe_diem
scanners?
I need one to accomodate '87 and '89 Fords with EEC-IV and also for '93 GM with OBDI.
I used a snap-on mt2500 scanner, which can accomodate all of these, but it is expensive. Hundreds. Are they all that expensive? Any alternatives to snap-on scanner?
Old May 27, 2004 | 07:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Do you mean a code reader?
Old May 27, 2004 | 10:54 PM
GypsyR's Avatar
GypsyR
I couldn't say on the 93 GM, but on the older GM's we just put a jumper wire across the diagnostic terminals and just counted the "check engine" flashes and looked up the codes in the manual. Thos may be different for 93's though.
On my 87 Bronco and 89 F150 the procedure is much the same only with the addition of a cheapo analog multimeter. Instructions and codes downloaded from the internet; free. Walmart multimeter; $6. Piece of wire for a jumper, laying around the garage. Total investment of $6, and the multimeter is useful for other things too.
Old May 28, 2004 | 09:22 AM
carpe_diem's Avatar
carpe_diem
Yes, I mean code readers.
I have tried all of the above. I jumped the pins on this '93 GM and the codes flash on the CEL. On my Ford sedan, I have cheapo Ford scanner which flashes out the codes. The Ford truck has the same interface of course, so I imagine that same scanner would work.
I tried the multimeter trick with the Ford, before I got the scanner, and I couldn't get it to work. Tried for 2 hours in fact, just made me mad. Not sure why. It seems so simple on paper.
If you want to pull codes often, a real code reader is the only way to go, as counting the flashes gets real tedious real fast. I used this SnapOn scanner, and it is nice. Also expensive as h3ll.
Old May 28, 2004 | 03:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is a thread here in GW on scanners that discussed various brands. I never did get my questions answered tho.
Old May 28, 2004 | 08:19 PM
mtascill's Avatar
mtascill
You might look into the mid-range scanners like the Auto-XRAY. These are in the $200 - $300 range but do more than just flash the codes. Mine is an XP240 for which you can get cables for Ford, GM and Chrysler OBD1. On some vehicles it will pull real-time sensor data as well as trouble codes, nice for diagnostics.
Old May 29, 2004 | 04:11 PM
rebocardo's Avatar
rebocardo
For under $200 you can get the AutoXray EZ-2000 that will read codes on the 93 GM and 87/89 Ford. I bought mine from northerntools.com. Make sure your code reader comes with the correct OBD cable. I had to return mine after using the wrong OBD II cable when it fried the scanner. Since the manual said "yellow" and all I had was green, I assumed that it was a misprint or an upgraded cable since the box said OBDII. It was not the correct cable. Happy news is I returned it to northern and they sent me out another new one at no cost.
It does not have all the bell and whistles as a NGS or Snap-On though it is very good for driveway mechanics. You will not be turning wiper motors on with it, reprogramming the CPU, and you can not do real time data mapping without upgrading it. Then again, your EEC does not support all that and I am pretty sure the GM does not too.
Old May 29, 2004 | 04:54 PM
fordnut1985's Avatar
fordnut1985
You can buy a scanner for the ford at autozone for about $30-$40. As far as the gm goes anything obd I can be read by jumping the terminal on the diog. port
Old May 29, 2004 | 06:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have been looking at an Equus/Innova 3100 OBDII code reader for a while. They are available at Advance Auto on sale at the moment for $129.
Those $30-40 code readers are for OBDI systems. You can use those readers to count the pulses for you or you can count them yourself. I always just counted them myself but then I am cheap. Unfortunately The OBDII stuff is beyond counting
Some of the high priced Scanners actually let you look at real time date coming from sensors etc. They are a real help if you have a loose wire or intermittent sensor such as the TPS etc.
Old May 30, 2004 | 01:44 AM
stepman's Avatar
stepman
Once again I have nothing good to say. I bought one of those autox-rays a while back. I had to have the best one they had with all the bells and whistles cause I have an OTC but, it only goes up to 95. (hadn't gotten around to updating it and thought this was a cheaper route) Spent like 500.00 on this thing and it was CRAP! It would tell me I had no codes when I could pull them by hand and see that I did. When I tried to take it back, they said" we can't take it back, it's been used" DUH! Enough of a rant...if you are just looking to pull codes then I would say go with the 30-40 dollar "code readers" at the parts store. They will do everything up to 95 or 96 (when obd2 started). Only thing is that they are usually manufacturer specific so you would have to buy a ford and a chevy and whatever else you wanted.
Old May 30, 2004 | 06:34 PM
carpe_diem's Avatar
carpe_diem
Autoxray EZ-READ 2000 Advanced Code Reader -- that sounds like what I want.
http://cgi.ebay.com/ebaymotors/ws/eB...category=43989
Old May 30, 2004 | 11:46 PM
stepman's Avatar
stepman
I would have to pass on that and keep looking. But, that's just me. Get another opinion. What's with all the ?marks? It will not give you all the same info that the dealers use. Do you think they would pay a couple thou for their scanners if it did? It is nice that it will give you codes for obd1 and 2. That I think is about all it will do though. I guess if you went and bought all the seperate readers you would end up spending about the same thing.
Firefighter 1406
16
May 14, 2022 07:17 AM
kupaa
Apr 4, 2010 07:44 PM
rangersvt04
Garage & Workshop
75
May 13, 2004 10:32 AM
e_no_g
Mar 21, 2004 11:14 AM
itsn0tus
Feb 19, 2002 11:53 PM
