No Power When Warm
Old May 26, 2004 | 11:12 PM
StevensPoint's Avatar
StevensPoint
No Power When Warm
What would cause my power to decrease (significantly) as the engine warms up????
I've got a '96 PSD with a 5sp and 226K. When engine is cold I have tremendous power and acceleration. As the engine warms up my acceleration gets worse. It's like it's starving for fuel. New Air and fuel filters. No codes are ever set. Thanks for any help.
Old May 26, 2004 | 11:22 PM
johnsdiesel's Avatar
johnsdiesel
Have you checked the fuel pressure or the high pressure oil pump? Those might be a couple of things to start with.
Old May 27, 2004 | 12:09 AM
StevensPoint
I took off the HPOP reservoir cover - things looked ok. I took out the filter housing/pressure regulator and thoroughly cleaned both, replaced all o-rings and fuel screen between the two. No codes are set for the ICP or IPR. I'm about to start replacing these things, but that's a lot of $$$.
When cold it seems like I have instant turbo boost. When cold it takes longer to get boost. I have yet to hook up a boost pressure or fuel pressure guage. Where do I get a boost guage?
Thanks
Old May 27, 2004 | 07:32 AM
StevensPoint
I meant to say "when warm it takes longer to get boost."
1996_powerstroke
13
Mar 10, 2016 08:50 PM
WhiteBeast-05-powers
Nov 9, 2013 12:47 PM
tomtek
May 12, 2010 10:40 AM
vze2sgxa
Jan 19, 2006 06:24 PM
CowboyBilly9Mile
1983 - 2012 Ranger & B-Series
Oct 6, 2003 06:24 PM
