Aerostar Ford Aerostar
lowered minivans
Old May 26, 2004 | 09:36 PM
suprajztwenty's Avatar
suprajztwenty
lowered minivans
has anyone lowered their van with a torch? ive heard of people doing it and i was considering it. but what are the consequences of doing it? im sure youd have to heat the spring evenly, but even still, would it make the ride stiffer or more bouncey? anyone here done it before? please, any advice, i want to know before i get darring and go and do it. thanks
Old May 26, 2004 | 09:48 PM
jkorreck's Avatar
jkorreck
When you heat a spring like that you weaken the spring metal, I'd think that would be a bad idea, I just replaced a set of snaped springs on pontiac lemans that when they broke bottomed out the car and damaged the oil pan. If you want to lower it I'd look for another way.
Old May 27, 2004 | 04:49 PM
suprajztwenty
what if i took a plasma cutter and just cut part of the top or bottom off? it wouldnt weaken as much. also im only going for about 2" of drop so its not too dramatic. thanks for the advice thogh
Old May 27, 2004 | 05:06 PM
copper_90680's Avatar
copper_90680
The springs on these Aerostars are inherently weak anyways. If you want to lower it 2", drive around with a couple of Sumo wrestlers for a couple of weeks. That'll do it
Old May 28, 2004 | 08:50 PM
suprajztwenty
pretty much done that already (not really, lol) but it was a work van for my dads roofing company. so i was always loading way too many shingles on it. there was plenty of times that it sat down on the axel all the way to the place. so that doesnt really do the trick. actually the rear end looks higher than normal. but does anyone think cutting the spring is a better idea than heating em? thanks for the great advice though.
Old May 28, 2004 | 10:03 PM
copper_90680
Once you lowered the van, then what happens to the shocks when the springs bottom out over a big bump? I have never been the adventurous type, so I tend to look for reasons against doing somthing like this
Old May 29, 2004 | 02:30 PM
xlt4wd90's Avatar
xlt4wd90
Yes, cutting the springs would hurt them less than heating them. They would keep the same temper, and removing a coil or two will help stiffen them up a little, but probably not enough to compensate for the reduced travel. You would also need to reform the end that you cut somehow. As I recall, the top end is flattened, and the bottom end has a tight pig tail curl, and both ends have retainers that are bolted to either the frame or lower control arm.
Are you just trying to lower the van for appearance? If you don't do this right, you can really hurt the suspension and the way it handles can be dangerous.
Old May 29, 2004 | 04:08 PM
JTHill24's Avatar
JTHill24
Why not just get a set of spring compressers. My brother had a set that he put on his truck that squeezes the center of the springs together and makes the truck sit lower. No Cutting, No Heating, & if you gey tired of it just remove them.
Old May 29, 2004 | 05:37 PM
suprajztwenty
i like the compressor idea but ive never heard of them before. i really dont know how im going to lower it, but i decided im only going to lower in the rear. 18" rims and tires in rear, 17"s in front. i only want the rear to lower a little to make the wheel fit better in the well. as for the fronts, i dont think ill have to lower at all, but you never know. thanks everyone that posted.
Old Jun 4, 2004 | 07:45 AM
Uncle Stumpy's Avatar
Uncle Stumpy
you can't cut the back coils (double tapered) so torching them is the only option. I did it on mine before I put in the airbags. works but you get an extra sloppy ride. Buddy of mine found some short stroke shocks that fit (toxic shocks) that are made for lowered vehicles that helped a bit, but the springs were just too weak. The fronts are best cut as opposed to torching, once again you have to shave the bumo stops down and get a shorter stroke shock to avoid blowing the seals.
finally got the front airbags in mine the other weekend. it was a pain relocating the shocks but I've got a couple hundred miles on it sence and it rides like a caddie an will "lay down" at will.
Old Jun 4, 2004 | 12:56 PM
suprajztwenty
thanks, ill take that advice. i probly wont lower it. you all saved me tons of time and money, thanks.
Old Jun 7, 2004 | 07:40 AM
Uncle Stumpy
Common, just torch the backs and cut the fronts, what do you have to loose? You can get new springs if you screw them up they aren't that expensive.
No pain, no gain, go for it my man!!!!!!!!!
NW 150
May 28, 2012 02:49 PM
dchamberlain
Jul 26, 2011 09:58 PM
Alfster
15
Oct 25, 2006 07:23 AM
fancyplaya
1983 - 2012 Ranger & B-Series
Aug 20, 2003 08:55 PM
